Question about A4tech A4 tech G6 saver Mini Wireless Desktop Keyboard Mouse (878577003768)
Keyboard Model GSK-5 is not owrking although mouse is working. It happens after the installation of new windows. Although I have changed batteries but no avail.
Hello I have lost the reciever of a4tech model= GSK-5
if some one is able to help me please contact me at these ids
aftigher1876@gmail.com
Posted on Dec 03, 2016
Logitech K330 numeric keyboard does not work
I had the same problem and found the solution in a ubuntu forum. Although I use ubuntu, I am currently using windows and oddly enough the solution is same for both platforms. Just change your mouse settings to stop using numeric keypad on your keyboard as mouse. In windows 10, type "Ease of Access mouse settings". Turn OFF "Use numeric keypad to move mouse around the screen". And that should fix it.
Mar 07, 2014 | LogiSys Computers & Internet
Hi my wireless keyboard & mouse do not work at all on my Acer Aspire M3970, but both a cable keyboard & mouse do?
There is a USB receiver underneath the battery panel of the mouse, although it looks like part of the workings of the mouse. It's only a very small thing with a USB plug on it but it is there. The instructions don't show a picture of it, so it's very easy to think you haven't got one until you look closely
Unclip it and put it in your USB port and it should come up.
Nov 10, 2011 | Computers & Internet
HID keyboard (ACER) FCC ID: E8HKBR0355 Model number: KBR0355 stopped suddenly although the keyboard is working, changed battery but not working
i have restarted my PC and as my mouse is working, i make sure the the wireless connector is working i pressed the button at the middle of it to make it blink contentiously and then pressed the button at the bottom of my keyboard, that is it.
Dec 16, 2009 | Acer Wireless WIL-152 91.84R07.152...
Wireless keyboard and mouse stopped working
try to replace the battery on mouse and the keyboard with new battery put you mouse and keyboard close to the computer, see what happen,
Mar 29, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
I have a logitech which used to work with window vista home premium 64 bits version. Today it is not connecting although i replaced the batteries and the light in the back of the mouse is dim and sometimes...
THE MFG MAY HAVE A CERTAIN BATTERY REQUIRMENT, NEED TO GO LINE AND LOOK UP THAT INFORMATION, DEPENDING ON THE MFG AND THE BATTERY COMPANY THEY WANT YOU TO USE IF YOU DONT USE THERE BATTERY REQUEST THAN YOU WILL END UP BUYING A NEW KEYBOARD OR MOUSE WHEN THE BATTERIES RUN LOW.
LOOK FOR A LITTLE PIN HOLE ON THE BOTTUM OF THE MOUSE ALSO EVERY TIME YOU CHANGE THE BATTERY YOU LOOSE THE FREQUENCE THE MOUSE USES, SO DEPRESS THE BUTTON UNTIL THE COMPUTER SAYS IT HAS FOUND A NEW PIECE OF HARDWARE, THAN THE MOUSE SHOULD WORK FINE.
GO ON LINE AND SEE IF THERE ARE ANY NEW UPDATE FOR THE MOUSE
RODGANDYSR
Mar 05, 2009 | Logitech Cordless Mouse
1 USB Port Failure
Hi Guys
Unfortunately after looking at the computer installation details i was at fault, although i have had
the computer for well over 2 years and this is the first time it has happened.
My Dell Dimension 5150 has 7 USB ports 5 at the back and 2 in the front and it appears that i have
connected the keyboard and mouse to the wrong ports.
There are two ports at the bottom allocated for the keyboard and mouse and for some reason i had
them in the top three ports hence my problem but still not sure why it happened.
Anyway my Dell Dimension 5150 is now running OK and no further help is needed.
Many Thanks.
Nov 03, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Logitech Wireless Keyboard not resetting evidently after installing new batts.
First make sure the batteries are put in with correct polarity. Although obvious, its surprising how many people make this mistake. (Happened to me too once :)
I am not sure what model you have, so please try the following:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=7652
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3818
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 29, 2008 | Computers & Internet
Logitech cordless mouse problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Nov 18, 2007 | Computers & Internet
Keyboard not working...
Have you pressed the connect button on the bottom (or side) of the keyboard. Having the mouse working means that all the rest of the kit is working, (as the reciever can connect to the mouse) if the keyboard will not connect (after pressing connect a few times)it seems that you have a dud transmitter in the keyboard, This does happen unfortunately (the oscilator crystal fails) if within warrantee try to get it replaced. Hope this helps
Aug 09, 2007 | Dell Wireless Keyboard Optical Mouse w0147
A4tech A4 tech G6 saver Mini Wireless Desktop Keyboard Mouse (878577003768) Logo
111 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
