Question about ASUS WL-500W Router (WL500W)
Can't connect my USB disk
I have connected my WD MyBook 250GB to the router I see connected UDB device in Router configuration enviroment. But I con not to map this USB device to my computer. I see WORKGROUP as well as DEVICE but stil can not to map it
  • richi333 Aug 09, 2008
    I cannot even see any USB storage device I plug into the router. I tried 2 external disks, a flash drive to no avail. When trying to add an USB node, the ASUS folder manager doesn't see any folders. Any clues?
  • Anonymous Jan 09, 2009
    usb storage couls not be recognized . because ntsf file system is not suitable for the router. It is advised to solve this change the file system to fat32 or ext2 . in my opinion asus engineers must think about all file systems...
  • 1,224 Answers
You need the disk
this has special file on it to run usb i forget which file it is but i believe its in the 386 file on your router
other thing is you cannot use usb with a router you have to use ethernet to connect direct usb is a single setup on modem when you add a router you have to go ethernet i had to do it with mine after 2 days when i first hooked my router i called the company and found out about this thought i would pass the info along
Posted on May 17, 2008
Cannot get 1TB WD MyBook to work on NetGear N600 Router
this link is quite illuminative
click here please
seems that drive configuration needs to be done when connected to pc first then after it's recognized, added to network router
May 21, 2012 | Western Digital Computers & Internet
Driver not shown on my computer/wd my passport 250gb
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
hope this helps you
Jul 13, 2011 | Western Digital 250GB MyBook External USB...
I can not connet my WD to the Cuputer
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: for a "no data - no charge" guarantee.
Dec 12, 2010 | Western Digital 250GB MyBook External USB...
Mybook WD25001032 is no longer recognized by my computer. how do I recover the data.
Disassemble the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" drive in a desktop computer, and see if you can access the files.
Nov 01, 2010 | Western Digital 250GB MyBook External USB...
The drive letter for my external USB hard drive (MyBook) has disappeared from Windows Explorer. I tried My Computer/Manage/Disk Management and it is not listed there, either. I also tried powering down...
If it's not visible under Disk Management, then it means that your drive or cable is faulty. If the drive powers up when you connect the power adaptor, the cheapest thing to try is another USB cable. WD uses a standard A->miniB USB cable which you should be able to purchase easily - just take the original cable with you for reference of the mini plug, as there are a few different ones on the market. Or you can borrow such cable from a friend that has an MP3 player, an USB hub or similar device with same type of socket.
If this fails, I'm afraid it's the MyBook that's broken.
Oct 25, 2009 | Western Digital 250GB MyBook External USB...
Hi, my WD hard drive is connected to my macbook, but can't access
check under the system profiler which can be found in the applications folder and then in the utilities folder. See if under usb whether the drive is showing under there. If it is, open up disk utility and use the verify disk to see if there is a problem with the drive, if there is use the repair disk to repair it.
Other things to check try a different usb port on the macbook or a different usb cable.
Hope this helps
Oct 21, 2009 | Western Digital 250GB MyBook External USB...
I have recently bought a Belkin N+ Wireless Modem-Router (model F5D8635-4 v1). It comes with the USB port and I bought a WD 1Tb drive to connect with it. I added the WD drive ( Book in my...
  • First off, the WD hard drive was meant to be connected to a computer.
  • Therefore connect it to the fastest computer you have or the one running the network.
  • Make that drive a network drive.
  • Set the router to handle DHCP using the web based interface ( on a linksys router, check your manual for the IP address belkin)
  • The drive apparently has three volumes on it: X: Y: and Z: (network drives)
  • I would backup the WD drive and reformat in NTFS format
  • I dont believe that these drives were meant to be networked. Therefore you get what you get....
Good Luck
Sep 14, 2009 | Computers & Internet
WD My Book 1TB Ethernet seems to hang my USB ports on my notebook
Update your firmware, i had the same problem, i updated the firmware and everything works fine now.
Jul 04, 2009 | Western Digital Computers & Internet
USB dard drive extermly slow
common problem with larger size drives, windows is trying to populate the entire contents of the drive at once. try to keep single files out of the root drive (aka put your files in folders) that way when you access the drive it will just populate a bunch of folders instead of a million individual files
Jun 04, 2008 | ASUS WL-500W Router (WL500W)
Open Questions:
ASUS WL-500W Router (WL500W) Logo
397 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
