Question about Microsoft Xbox 360 Console
Xbox wont read disc. it says open tray. - Microsoft Xbox 360 Console
    President:
  • 1,566 Answers
This is a problem with the lens on your XBOX. Try to use a lens cleaner to remove any dust or dirt on the lens. And still, if it does not work you can try to "slam" shut the disc tray. You can try the steps in this video:
http://www.youtube.com/v/oPhZv2Ffmew?fs=1&hl=en_US
Let me know how it goes. And please provide a feedback.
Posted on Sep 15, 2010
oblivion2k
  • 150 Answers
SOURCE: Xbox Disc Tray Loose
If you are comfortable with taking apart your system, I would advise taking the case off and then finding the dvd-drive, removing the case on that and simply tightening the screws on the tray. Don't tighten them too much, but make sure they are snug. Then test to see if it still wobbles and it should be fixed. If you are not comfortable with taking apart your system you will need to find a repair shop that can do it for you.
Please rate, thanks!
Posted on Mar 31, 2009
  • 46 Answers
SOURCE: wont play/read any xbox games
1 dirty lens
2 dirty disc
3 programme error
1 i think the xbox cleans its own lens but check the manual if not get a good lens cleaner.
2 clean the disc always clean your discs after and before you use them.
3 take off your hard drive and any memory cards and reset xbox to factory settings
Posted on May 12, 2009
  • 34 Answers
SOURCE: I turn on my xbox 360 and it says open tray and wont read disc
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
Posted on Jun 23, 2009
justin217
  • 85 Answers
SOURCE: My xbox 360 wont play discs - keeps repeating open tray.
Call microsoft at 1-800-4-MYXBOX
Posted on Jul 15, 2009
NinjaKoriku
SOURCE: hello my xbox 360 wont read a disc it says open
Your Xbox's disc drive is most likely broken. This happened to me about a month ago to a used xbox I had bought. You should call Xbox Live Support. They are very helpful.
Posted on Dec 14, 2009
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
Loose disc tray
well, when you opened the tray with a paperclip, it probably jacked up the reading system. The you pushed it in manually. This will totally ruin the system. Try contacting Microsoft.
Jan 16, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
Xbox wont read a disc
The disc maybe scrathed or dirty so it can't be read. Or it might it doesn't supported the disc's data
Sep 08, 2009 | Microsoft Xbox Console
Disc reading problem
use a disc based lens cleaner. opening your xbox console will void your warranty.
Aug 20, 2009 | Microsoft Xbox 360 Console
My xbox will not read any of my games
try playing a different game *******
Jul 29, 2009 | Microsoft Xbox 360 Console
Xbox wont read discs, unless i hit it....
open tray right??
-check the time and date settings,even the time zone as well
-try to load the disc without the hard drive or memory unit
-look for corrupted files at the memory, delete it
-do the system maintainance,
system settings>>memory>>hardrive, press y for device options, press this in sequence x, x, Lb, Rb, x,x>>yes
Jun 27, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
the lens of the disc drive needs a check up...
May 29, 2009 | Microsoft Xbox 360 Console
My xbox wont read any of my disc keeps on saying open tray
HI, the DVD-ROM drive is malfunctioning. this will usually start with a failed optical lens assembly issue but, this is a bit different. The actual spin motor has failed first in this case. due to this damage, you will need to replace the DVD-Rom drive asap. this will fix this issue.
May 15, 2009 | Microsoft Premium System for Xbox 360
Wont play/read any xbox games
1 dirty lens
2 dirty disc
3 programme error
May 12, 2009 | Microsoft Xbox 360 Elite Console
Microsoft Xbox 360 Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
