Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Have a cub cadet ztr. need wiring schematic. no power to pto. replaced switch no help. model # 17aa5d7p756
  • 69 Answers
SOURCE: I can not get my mower deck to turn when I pull
Your switch could be bad, or the voltage needed to turn on the PTO may not be up to par, or you may have a safety switch that won't let you start the PTO. I'd start with the safety switches.
Posted on May 11, 2009
  • 218 Answers
SOURCE: Cub Cadet PTO will not engage
Do you have a volt meter or a 12 volt test light?..if you do you can see where you are losing your voltage at..but i would suspect the PTO switch is bad..i hope this has helped.....Keith
Posted on Jun 30, 2009
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
  • 16 Answers
SOURCE: Cub cadet lt 1050 electric pto want engage??????????
make shure pig tail is hooked right
Posted on Oct 17, 2009
SOURCE: electric pto clutch will not engage garden tractor -cub cadet gt1
the electric clutch jhondeere won,t engage
Posted on Apr 30, 2010
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Cub Cadet,model 2135. Is there a relay betwee switch and electric pto?
a short on the hydro wire have to find chase the wires from pto back if you dont find it take it in because if you dont you will burn up the stater
Sep 19, 2014 | Cub Cadet Garden
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
What does PTO stand for
power take off which drives the belt that runs the mower deck sounds like a dead short in the pto clutch maybe a wire shorting out check for bare wires
I need a wiring diagram for a 3165 Cub Cadet Lawn tractor. I need to know where the 2 green wires in the wiring harness go.
My name is Dane and I am going to try to help you solve your problem. Here is a link to where you can find your 3000 series manual. The wiring schematics start in chapter 13.
http://www.mymowerparts.com/pdf/Cub_Cadet/Cub_Cadet_Service_and_Repair_Manuals/
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Dec 04, 2010 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Jul 06, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet mower pto will not stay engaged while cutting? has new belt any suggestions
be sure your battery is good and your system is chargingning the battery while run
Apr 12, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
268 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
