Question about Dishwashers
I have a Bosch dishwasher (SMI5072), bought in 2005 second-hand but working OK. It has always been a little slow to get going, and I had initially thought the clockwork program dial was getting stuck. Then I concluded that it had something to do with the filling up process, and I thought it must be because the water was rather cold and paid no more attention to it. This has meant that it seemingly takes ages to get through a cycle. Yesterday I put it on, left it and got on with some work. An hour or so later it twigged that I hadn't heard much from it and I went to look. It had clearly got as far as the wash cycle because the soap stuff was now in the base of the machine, and the dishes looked oddly enough quite clean, but in fact had not been washed. I reran the cycle and stood by - it drained but there was no sound f incoming water. So we have taken it apart - well the sides off! It simply does not fill. If we throw in a few litres of water it will happily carry on. And it drains OK. The red switch on the left side of the chassis works because when I lift it using a chopstick (LOL) the clockwork dial progresses. The floaty mechanism that should move that switch also works (lifted gently using a souvlaki stick (!)). The water supply is fine (got soaked yesterday proving that) and the filter connecting the inlet box with the lightning symbol on it is clear. I have some pics if required. What do I check next and how? I have been unable to find a manual for this anywhere. Thanks Sue. (got multimeter).
  • 1 more comment
  • drzeus_gr Sep 16, 2010
    Thanks again. I kno a lot of people will think 'just get a new one already' but they cost an arm and a leg here and a tech will likely be 100 euros, and a waste of space if there are no parts to be had.
    I have no idea how old this is - can you tell me from the FD number?
    The float switch itself appears to be fine, just unable to work because it won't float up without water going in. We added water as best we could and gave it a spin - all fine. I tried taking out every drop of water and letting it 'sleep' in case something needd to reset ... no change. The only thing I did 'discover' today, after trying again, is that starting from program initiation, there is the sound of the pump draining the machine, then sort of swishy swashy sounds, then there is a click from the top panel, like the click of the red switch, and then nothing at all.
    At the risk of sounding thick ... where exactly is the water inlet valve?? We have traced back the hose from the water inlet pipe to the machine ... but where it connects is not easy to get at..
    Just so you can see exactly what is behind our toekick panel ... check out http://www.flickr.com/photos/drzeus_gr/
    Which bit am I supposed to be looking at as the inlet valve?
    Many thanks
    Sue
    Many thanks
    Sue
    Many thanks
    Sue
    President:
  • 1,430 Answers
There is a screen inside your water inlet valve that may be clogged. You will need to see if you are getting power to the water inlet valve when the machine calls for water. If you have power replace the water inlet valve ( not uncommon in older Bosch) If you do not have power you will need to check the float switch and or control. Here is a link that should help http://appliancehelponline.com/dishfloatwaterinletvideo.html
Posted on Sep 15, 2010
  • 2 more comments
  • drzeus_gr Sep 15, 2010
    Thanks for replying so quickly. I had already seen the video but there is no float switch like that in the video in mine (the inside contains nothing but the rotor arms, salt container and filter base). I also have not yet been physically able to get to the other end of the water inlet.
  • marka19
    marka19 Sep 15, 2010
    The float switch is attached to the arm you were moving with the chopstick. The water inlet valve is behind the toekick. It has a couple screws that attach it to the frame. Remove the water supply line first.
    Many thanks
    Sue
  • svims Oct 01, 2010
    I have a Bosch SMU3632/08, with exactly the same problem! Based on your pictures the dishwashers are almost identical when it comes to construction and design. Have you found any solution toyour problem?
    Our dishwasher has worked without any problems as long as we've had it, but suddenly the water filling cycle changed. It used to be a clear, pretty loud flushing sound of water rapidly filling into the machine before starting the washing cycle. Now the water is flowing very slowlyinto the machine.
    I think have isolated the problem to the aqua stop magnestic inlet valve (the unit outside the dishwasher attached to the water supply). The filter entering the valve was not clogged. Any other experienced similar problem with the magnetic valve?
Dishwasher will not pump water out
The impeller of the pump-out pump siezes OR the impeller siezes because the water seals inhibit it from turning.
Problem well described in Owners Manual.
Yo may need to empty with a bucket initially.
Under the filter plates, there's a plastic access cover to the impeller.
You need to remove 1 Philips Head screw, the cover lifts off, and you can see the impeller, it is about 25mm (1") in diameter.
Remove any foreign material in or around the impeller.
Spin the impeller by hand.... it sometimes feels a little resistant, as though the seals on its shaft are gripping it.... this is OK.
Reassemble and try it out.
Good Luck
Dec 21, 2010 | Bosch SHU9915UC Dishwasher
Bosch Exclusiv - bought recently second hand so don't know the age, but problems with cleaning. When it does clean the dishes there is a residue on the items. Tried cleaning the jets with white vinegar...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Apr 04, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Model SHU4006UC problem
OK.. I'm a little confused.. I looked up the model # you have posted and found that there is no dial to turn on your dw... unless its the wrong model #.. it only have push buttons.. Anyway.. I think its your control.. yes, you can ohm out your elemnt if you can get to it..there is also a switch that is in series w/the heating elemnt.. make sure that is working.. from my trainning, most of the time its the control.. look for burnt mark by the 110-120v where its plugged in on the control.. let me know..
Jan 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
170 people viewed this question
Top Dishwashers Experts
