Question about Canon PC-D340 All-In-One Laser Printer
There is a code E000, and I can't resolve this problem, I need your help, could you tell me what is the cause of this problem and how to resolve it? Sincerly
  • 70 Answers
Here's the definitive reset. on your printer..
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press Unplug printer and repower it.
Posted on Sep 15, 2010
Testimonial: "I try it and its resolve my problem, thank a lot for your help."
How to reset error E000-000 for Canon ir2202
To help you understand and troubleshoot the error E000-000 for Canon ir2202 printer, please follow step-by-step instructions given below:
This error occurs due to high temperature readings on the printer. Occasionally, the fuser will run too hot. First thing is to perform factory reset on your canon printer but if it still show error code E000-000 again, then try to reset it in Service Mode. To do these, follow the steps below:
- Press ADDITIONAL FUNCTIONS, #
- Go to #7 Printer and Press OK.
- Go to #4 Printer Reset and Press OK.
- Yes = ( * )
- Power cycle unit.
Now check it the error is resolved. If issue persists, please try definitive reset. To do these, follow the steps below:
- Press Additional Functions key.
- Press #
- Press > to #7 Printer Function.
- Press Set.
- Press > to #4 Printer Reset.
- Press Set.
- Press <
Now restart the printer and check if it resolves the error. If issue persists, it is recommended to contact Cannon Support Center from the link given below:
https://www.usa.canon.com/internet/portal/us/home/contactus
GuruAid.com
Jun 14, 2016 | Canon Office Equipment & Supplies
How to resolve problem for canon imagerunner 2420L pritner error show "restart if problem persist "
There should be an error code on the screen too, what is it? it should start with E
Sep 06, 2014 | Cannon Office Equipment & Supplies
Error code e000 0000
If Error code is E000 then may be major cause:
+ The thermistor has an open circuit or short curcuit
+ The heater has an open circut. The thermal fuse has blown
+ The power supply PCB has a fault
+ The engine controller PCB has a fault
To Fix Error code E000 of Canon LassetJet LBP-3300 printer, you can try the following:
+ Check connector of the fixing film unit
+ Replace the fixing film unit
+ Replace the power supply PCB
+ Replace the engine controller PCB
This is not a job for a novice. Get a service technician to service the unit.
Apr 23, 2014 | Canon LBP3300
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
Have a problem E000
This error code means that your heater system that melts the toner onto the paper has failed. So you could try to reset it with a code, but since you did not mention which Canon copier you have, I am unable to tell you how to do this. Though, quite honestly only maybe 10% of these problems are resolved by resetting the code alone. This code almost always comes up because there is something broken or dirty inside the copier. The last 10% is usually a software glitch caused be a power fluctuation or power outages in your area. Repost your question with the model number if you had a power problem in your area and you want to try to reset the copier with a code.
Dec 17, 2009 | Canon ImageClass MF6540 Copier
Error Msg E000
E000 is a fixing unit failure...either the thermistor or fixing lamp failed. Not sure about individual part replacement, most likely needs entire unit replaced....then reset the code.
Aug 03, 2009 | Canon Office Equipment & Supplies
E000
e000 is fuser temperature too low could be disconnected or the over heat senser has to be replaced and this code must be reset in service mode to allow copier to function.
May 12, 2008 | Canon imageRUNNER 1630 Copier
ERROR CODE E000-0320
A E000-0320 code is a fixing unit error code. It is either not warming up or it is getting to hot. It is a thermister is shortting out or a thermal fuse or one of the heating lamps are blown.
Apr 14, 2008 | Canon CLC 4000 Copier
Canon PC-D340 All-In-One Laser Printer Logo
246 people viewed this question
old marine
old marine
