Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Either of my bissell porheat turbo 2x or my bissell pro heat don't have suction i would like to try and trouble shoot if i could due to the fact i am having difficulty finding a small machine repair center in my area could you possible help me or send a link which could help me find solution these machines are not more then a year and a half old if that thanks for your time and help warmest regards rebekah majors
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 22, 2010
When bissel turbo steam cleaner wont suck
google it:
My ProHeat 2X® is not suctioning properly. What ... - Bissell
www.bissell.com/faqdetail.aspx?id=1124 BissellAnswer: Let's start by figuring out where your carpet cleaner has suction. Check for ...If the Lint Screen is dirty, the suction won't be very strong. Cleaning the
Jul 20, 2015 | Vacuums
Why won't my Bissell pro heat wont suck up water with the upholstery tool
You may have a valve that switches from floor suction to tool suction. This could be not deployed or stuck.
Nov 09, 2014 | Bissell 2X Proheat 9200 rug cleaner
Bissell proheat 2x troubleshooting
depends on the suction capability generally the are slower than the bottom as you don't have to go over this with as much power/force hopes this helps
Apr 15, 2014 | Vacuums
Bissell pro heat will not extract water from the carpet
Try checking the top section of the machine (where the dial is located to switch it from floor to tool) and there is a little red plastic piece about 1 inch square on the inside of it. This is a lint filter that has a little door on it. Open the door or remove the entire thing to clean it out. It is probably completely blocked with hair, etc.. which is why you have no suction. Replace it after you clean it out and hopefully your problem will be solved!
Sep 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brush will move when up but as soon as you put it on the floor it stops! this is for the Bissell Proheat turbo 2x
The brushes are vacuum powered, me thinkest. Check for pluggage (view window?) and that suction is not being diverted to the upholstery side.
Regards, --WoobieDog--
Jul 10, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Mar 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel Pro Heat Turbo attachment does not work.
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes
Hope this is helpful.
Good Luck!
Jan 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pro Heat Turbo 2X
Here are things to check when there is no spray from hose or nozzles.
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
May 29, 2008 | Vacuums
Bissel Proheat 2x "catches" when it is pushed forward-- Help Please!!!!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=499675
Bissell ProHeat 2x "catches" when it is pushed...
Posted by Marlene101 on Apr 08, 2008
My ProHeat 2x bucks and catches when I try to push it forward-help!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Bissell 9500 ProHeat 2X Clean Shot Upright
The Bissell is not designed to be like a vacuum – it is designed to clean on the pull back, you dispense the Bissell cleaning fluid, the brushes scrub the carpet and the suction will vacuum up the excess water, the push forward will do the reverse action. You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owner’s manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Apr 08, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
109 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
