Question about MTX Thunder 8000 T8154A Car Subwoofer
Car capicator i just bought a car capicator for my subwoofers how do i wire the both of them to my battery
  • 26 Answers
HI DUDE....Car capicator - f39dd01.gif POWER COMES FROM BATTERY GOES TO UR CAPICATOR ... FROM CAPACITOR GOES TO UR AMP
Posted on Jun 15, 2009
    Scholar:
  • 45 Answers
I think the type of capacitors you are talking about are used to keep power spikes down. If so they are going to be wired in between the battery and the sub amplifier(s). The cap will need to be as close the amp as possible and be grounded with a separate heavy gauge cable, preferably to a different spot than your amps ground. The power wire from the battery will be connected to the pos. terminal on the cap. A second lead will run from that terminal to the amps pos. input. With the cap as close to the amp as possible and the cables from the cap. to the amp as short as possible and as thick as needed for your power requirements. Your ground wire should also be thick (heavy gauge) and short, terminated on clean paint free metal surface of your vehicle. The power wire from the battery should also be as thick as needed-more is better here so don't be afraid to spend some money. THERE IS ALSO A VERY IMPORTANT NOTE ABOUT CAPACITORS-you should slowly charge the cap before connecting the lead from the battery, not doing so is DANGEROUS. You can use either a 12volt light bulb or a small resistor to charge the cap. One side of the resistor or the light is connected to the battery lead and the other to the pos. of the cap. If you are using a light bulb it will indicate charging by lighting up. If you use a resistor you will need a voltmeter to check your progress (be carefull with either of these methods they can be a little hot on your fingers). When done charging, hook up the battery wire and you should be good to go. If it was done right and you have the right size caps for your setup the following things will occur and not necessarily in this order.
1. Your headlights are no longer dancing to the beat.
2. Your rear veiw mirror is harder to see through.
3.You will not have to replace your alternator or battery in your car anytime soon.
4. A smile will appear on your face as you plan your next move towards world domination!
Well maybe not the last one.
Dynami-
Posted on Mar 31, 2009
2011 holden cruze radio wiring diagram
2011 Chevrolet Cruze Car Radio Wiring Guide
Car Radio Battery Constant 12V+ Wire: Red/Dark Green
Car Radio Accessory Switched 12V+ Wire: N/A
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: Dark Blue
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 1? Tweeters
Car Audio Front Tweeter Depth: 1?
Car Audio Front Tweeter Location: 1?
Left Front Speaker Positive Wire (+): Dark Blue
Left Front Speaker Negative Wire (-): Brown/Dark Blue
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Yellow/Black
Car Audio Front Speakers Size: 6 1/2? Speakers
Car Audio Front Speakers Depth: 3 1/4?
Car Audio Front Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Dark Green
Left Rear Speaker Negative Wire (-): Dark Green/Black
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Dark Blue/Black
Car Audio Rear Speakers Size: 6 1/2? Speakers
Car Audio Rear Speakers Depth: 3?
Car Audio Rear Speakers Location: N/A
Car Subwoofer Speaker Positive Wire (+): N/A
Car Subwoofer Speaker Negative Wire (-): N/A
Car Subwoofer Speaker Size: N/A
Car Subwoofer Speaker Depth: N/A
Car Subwoofer Speaker Location: N/A
Jan 02, 2016 | Holden Cars & Trucks
Tip
How to install a subwoofer and amplifier
When installing any electrical components always remember to unhook the battery. First thing you want to do is run your ground cable from a volt meter to a body or frame nut or bolt near by in the trunk or hatch area a shorter thicker ground is best then connect the other end of your volt meter to your battery cable that will need to be run through the firewall and connect to the positive battery terminal. Also VERY important make sure you have installed a fuse on the wire in between the amp and the battery. after you have connected the battery cable and ground to your meter it will light up or give you the correct reading for your ground, if not run the ground somewhere else until you have found the right spot. pull out your stereo, for stereos that are made to be compatible with an amp there will be multiple rca jacks in the back of the stereo. For a sub woofer you want to hook the rca cable to the rear or sub labeled rca jacks. Then run your amplifier remote wire to the remote wire protruding from the back of your car stereo. After that you can run the ground and battery cable to the correct slots. Now connect your sub via rca and your done. making it fit correctly is up to you. If you do not have an amp with a subwoofer out then you can take the wires from your sub and bridge the connection to your amp and get enough power, take the positive wire to your sub and hook it up to the positive terminal of channel one on the amp then take the negative wire from your sub and hook it into the negative terminal on channel two and your done.
keywords: subwoofer, fuse, wiring, car audio, car , car audio install, speakers, dvd player, in dash, acura integra gsr del sol honda civic itr ls b16 hatch coupe jdmkey words: honda acura integra gsr itr jdm del sol coupe hatch ls si boosthonda, acura, civic, crx, si, hx, two door, integra, DA, EF, EG, EK, DC, DC2, DC4, hatchback, four door, GSR, LS, GS, RS, EX, DX, VX, engine, transmission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15,key words:VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, integra civic, b18, turbo spoon,JDM,EK9,da6,eg,civic,HB,honda,acura,turbo, acura Honda Civic Integra EG6 EK9 EK4 DB8 DC4 ITR CTR civic honda jdm integra ls gsr b16 b18 civic si crx k20 swap hatch coupe lx eg ek ef b20 accord prelude sedan trade sir type-r lsd b18c5 b18c1 turbo supercharger b-series integra da dc eg ek ex gs rs ls gsr lsr rs si sir sirg wanted prelude accord transmission eg ef ek em ep civic integra del sol s2000 s2k rsx accord gsr type r itr ctr vtec v tec honda acura blades ls mesh rota volk 4 lug 5 lug b16 b18 h22 h23 b20 k20 d16 d15 b series h series d series turbo all motor eg ek da ef crx dc2 dc5 dc em ej ap1 f20 prelude jdm edm ukdm doch b18a b18 b18c1 b18c5 rota rsx integra DA ef eg ek hx rims si rims gsr blades ls distributer distributor rota rotor aem injen akimoto parts works obx hatchback honda acura integra ls rs gs gsr type r civic dx cx ex hx lx si crx hf del sol oem jdm da da9 da6 db dc dc2 ef ef8 ef9 eg eg6 motor integra da dc eg ission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, suspension, break, brake, greddy, tanabe, cusco, zex, nos, turbo, drag, hks, aem,subwoofer powered subwoofer subwoofers svs subwoofer
home subwoofer car subwoofers best subwoofer subwoofer cable
subwoofer reviews car subwoofer klipsch subwoofer subwoofer wiring
home theater subwoofer yamaha subwoofer subwoofer amplifier
jbl subwoofer subwoofers for sale jackhammer subwoofer subwoofer boxes
hsu subwoofer sunfire subwoofer kicker subwoofers pioneer subwoofers
subwoofer car audio car audio subwoofers powered subwoofers
cheap subwoofers home subwoofers 15 subwoofer
subwoofer placement computer subwoofer active subwoofer
velodyne subwoofer mtx subwoofer kicker subwoofer subwoofer box
infinity subwoofer home audio subwoofers
car speakers and subwoofers
cheap subwoofer
home theater subwoofers
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
subwoofer enclosures
custom subwoofer boxes
on Jan 28, 2011 | Honda Civic Cars & Trucks
Replaced battery in my car on wedenseday car started right up got home turned car off car wouldnt strt back up took battery out put it back in car starte right up turned car off same problem occured
Ok, if you have a subwoofer system, ground wire going to the battery from the AMP is draining the battery due to improper wiring. Your best bet would be to contact a car audio shop or BETTER YET, go to one. They will definitely be able to help you out.
Aug 29, 2011 | Car Audio & Video
How to assemble boss sub woofer,any?
If you have already bought the subwoofer, you will need to buy an enclosure for it. As well, you will need an amplifier and a compatible receiver for the amplifier.
Once you have all of these components, you will need to wire them all together. For this, you will need a pair of RCA cables to run from the receiver to your amplifier, a power wire to run from your amplifier to your battery, and wire running from your amplifier to your enclosure/subwoofer.
For a more in-depth tutorial on how to install your subwoofer, check here:
http://www.wikihow.com/Install-Subwoofers
Mar 01, 2011 | Boss R12 Riot Series Subwoofers (12 ;...
I have a hifonics bxi2010D amplifier it keeps cutting out i have had it since august it was working fine until 6 weeks go and it started cutting out. But the protect light on the amplifer does not come on....
Whats your voltage at when the amp cuts out? Low voltage will cut the amp off. The cap could be bad, but if it is low voltage causing the problem I would check the battery and alternator 1st...hope this helps
Feb 20, 2010 | Car Audio & Video
1992 Mr2 electrical problems
These MR2s came from the factory with a subwoofer and 6 speakers...if your subwoofer has been removed and the system tampered with, you may just have to run a new power wire from your ignition switch and a new ground to your new unit. Just make sure that you wire it to the correct posts on the ignition switch.
Also, do not ground it to the battery...the electric powersteering will make a buzzing in the stereo anyway since it is not shielded, but if you ground the unit to your battery it will make it much worse. Ground your unit to the floor or some other metal surface close to your stereo. Hope this helps...I had the same problem when I bought my 1991 MR2. Good Luck!
Jul 18, 2008 | 1992 Toyota MR2
Power wire
You should run a new power wire to the battery or fuse box from the Sub. For safety there should be a fuse on the cable at the battery or fusebox end.
Mar 26, 2007 | Kenwood KSC-WA100 Car Subwoofer
Battery problem
I would recommend increasing your altinator and getting a yellow top battery. Basically what is happening is your using more power than the car can produce.
Dec 20, 2006 | Jensen BP212 Car Subwoofer
MTX Thunder 8000 T8154A Car Subwoofer Logo
51 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
hoyzee1
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
