Question about Sony PlayStation 2 (PS2) Console
Disk read error
Not the disk or dirty lens. lens stops moving halfway. (big ps2)
    Problem Solver:
  • 22 Answers
What you might want to do, is go to radioshack and buy a lens brush disk. i had the same problem and it really works, the maxell one works too, but if you get the radioshack one, there are 6 brushes instead of 2. Hope i helped!
Posted on May 16, 2008
My playstation 2 makes a weird clicky sound when I try to play some of my dvds or games and sometimes it comes up with disk error or unable to read disk and its a brand new disk
Your PS2 lens is displaced from its original position that is what scratching your Discs and makes weird noises too.There can possibly be another reason for them ,your PS2's reading lens is dirty and it is covered by a layer of dust that scratches your Discs and makes sounds too.
You should first clean the lens of your PS2 watch this video to know how to clean your PS2's lens:
Disk read errors are mainly due to dirty or worn out lens,so clean your PS2's lens to get rid of this problem and as for that sound that will get fixed by cleaning lens if still it makes that sound then you will have to take your PS2 to repairer to set the lens height.
Thank you!
Nov 30, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
its either a dirty lens inside the drive or a dirty disk. start with trying a lens cleaner.
Jun 12, 2008 | Sony PlayStation 2 (PS2) Console
Says can not read disk
Disc read errors are mainly due to worn out lens or dirty PS2 lens.Clean your PS2 lens to get rid of this problem if your lens is dirty.Watch this video it will help you to know how to clean your PS2 lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty.
Thank you!
Nov 27, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
Thank you!
Nov 25, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 game disc says disc read error, but there is nothing wrong with the disc
Most disk read errors that are not caused by the disk itself are caused by having a dirty lens in the drive you put that disk into.
Two easy ways to clean that lens are either buying a cd lens cleaner (cd with brushes on the underside of it) or by using a can of compressed air to blow the debris off the lens.
If you go the route of compressed air in a can, there is an extension that comes with the can...it usually looks like a mini red sipping straw. You can reach the lens by open up the drive tray and pulling the power to the console when it is open. The reason to pull the power is that you can now move the tray halfway closed without it auto closing on you. When you have access to the lens from positioning the tray, stick the extension into your console and place it right at the lens and press the nozzle to spray the air. Do this a couple times and try reading your disk again.
Hope this helped.
Sep 14, 2009 | Sony God of War for PlayStation 2
Disc keeps reading an error
the laser lens is most likely dirty.
Found this video on youtube on cleaning it
this one actually shows the guy cleaning the lens:
Note that it basically voids your warranty if you still have warranty on it.
Should solve it,
let me know how that goes,
Thanks,
Ekse
Jun 03, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 disk read error
THE LASER LENS AND OR HUB SURFACE is dirty
Dec 05, 2008 | Sony PlayStation 2 (PS2) Console
Will play CD's but not DVD's or Games
You have to take the box apart and clean the lens.Ok !
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Jun 06, 2008 | Sony PlayStation 2 (PS2) Console
Unable to load playstation dics or any other discs for that matter
Jun 05, 2008 | Sony PlayStation 2 (PS2) Console
I keep getting a "Disk Could Not Be Read" error.
maybe the lens of ur ps2 slim are dirty...if not you may need to replace it, coz lens get weak after a long time of stress using it...
Oct 08, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
