Question about Whirlpool Calypso GVW9959K Top Load Washer
Clothes are hung in bottom and unable to remove catalst model duncan1049@hotmail.com
  • Whirlpool Master
  • 8,220 Answers
I recently was able to work on one of these. Pop the outer agitator cap off and remove the screws holding down the bottom plate then you can fish out the clothes. Don't try to remove the inner agitator unless you just have to and makes notes.
More here
Posted on Sep 15, 2010
How do I clean leather car seats before polishing to remove dirt from the small cracks in the leather.Before applying leather polish.
Please use clean cloth first, remove the dirt from the small cracks in the lather and apply leather polish.
Dec 17, 2013 | hotmail.com
I have a Maytag Washer Model LAT9206BAE, I have cleaned the washer but my clothes are still getting a lint like substance on them. Is there a screen or something on the discharge that may be blocked.
There is no filter. You may have something that is hung up under the agitator. To remove the agitator, remove the fabric softener cup, then the bolt that holds the agitator on and lift the agitator out.
Nov 22, 2012 | Maytag Washing Machines
Makes scraping sound and clothes get hung up in front of drum. What parts need to be replaced?
When clothes get hung up in the space between the drum it means the seal is bad - probably your unit has glides that have worn (rollers make a banging noise)
Glides require removing the front of the dryer and pop riveting in new ones.
Go to searspartsdirect.com and enter your model number found on the dryer door jam (hidden when the door is closed). You can see the construction from the parts diagram
Sep 04, 2011 | Dryers
My clothes are being ruined in the dryer..I have the DCVH515 frontload model...clothes getting caught inside..i think some kind of seal from the inside around the door opening is gone..clothes are getting...
I have had the same problem for about 6 months. I have been sticking duct tape on the inside over where my clothes were getting hung/caught. It works :) but the heat makes the duct tape peel off so you have to keep replacing it. We finally had to call a repairman when the drum started making a horrible noise. He came out this morning and said one of the "sliders" the drum rolls on had broken. He said when the sliders begin cracking it can make a very slight gap where the clothes were getting caught. I have run 3 loads this morning and had only one dishtowel get hung whereas before multiple items in each load were doing it. He said there are multiple sliders so it may happen again.
He also said the clothes getting hung was an indication of a breaking slider so you may want to call a repairman to head off your drum doing what mine did. It cost me a total of $105 and I live in SE Texas.
Aug 02, 2011 | GE DCVH515EFWW Electric Dryer
Maf 1375 AAW front loader washing mahcine - water wont drain out???
Remove the back access panel. On the bottom of the tub you will see the drain boot. Remove the boot from the tub and check for any blockage. Also, while you have the boot removed, check up in the tub for any small pieces of clothing that may be hung up in there.
Feb 09, 2011 | Maytag MAH6700AWW Neptune Front-Load...
When getting water from the front of the fridge there is a leak at the bottom from the hose...how do I fix it?
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. A hung up ice maker was the culprit for this overload most likely. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 10, 2010 | Maytag MZD2766GES Side by Side...
INDESIT TUMBLE DRYER TRAPS CLOTHES AT FRONT OF DRUM - CLOTHES ARE RUINED. GAP AT BOTTOM OF DRUM ABLE TO GET FINGERS IN ..
that dryer is obviously a vented dryer. the problem you are having is that the drum itself is falling back off the front bearing plate(i have actualy got a call in the morning for the same fault) the solution is to remove the back panel from the machine and place a washer about 4mm thick between the drum and rear panel on the shaft. this will solve your problem.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Hotpoint Dryers
I have a shadow on the screen in the bottom right hand corner what could the problem possibly be.
It sounds like something has fallen or crawled into your tv. Unplug unit and remove the panel on the rear bottom. Now remove the upper part of the rear cabinet if you cannot see the problem. You will probably find something on the lense blocking the light. This would be a good time to clean the lenses. Using a soft cloth and windex, spray the cloth then gently clean each lense using a circular motion. Do not wipe until dry as you may scratch the lense. Do not spray the lense as you will cover critical components with corrosive cleaner. Do not push hard or disturb any lense adjustments. Reassemble unit and your tv should look as good as new. Let me know how this works out. hardrocko@hotmail.com .
hardrocko
Feb 01, 2010 | Philips Magnavox 51MP392H Rear Projection...
Unable to remove cloth cover to wash
Here's the official guide:
http://www.babyage.com/icons/localhost/products/multimedia/26078_3591328.pdf
Mar 10, 2009 | Evenflo Comfort Touch Vanguard 5
IPOD NANO 1st Gen. 2GB HANGED
THIS WILL SOLVE YOUR PROBLEM!
1.Turn on HOLD then switch it off
2. Press and hold the "Play/Pause" Button and the Center button at the same time until it resets the iPod.
This should reset your iPod and fix your hung (frozen) iPod!!!
Jun 27, 2008 | Apple iPod nano
Whirlpool Calypso GVW9959K Top Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
