Question about Xerox DocuColor 12 Printer
Can I color calibrate my DC 12? - Xerox DocuColor 12 Printer
    Champion:
  • 241 Answers
It need density meter which measures density of each dot
printed from colour pro tool
if you have density meter try it
otherwise do it from a service call
Posted on Oct 05, 2010
I owned HP CM1312 mfp. I have problem with color prints. No any color is printed except black. I changed dc controller but the problem remains... Could you please help?
I hope you did calibration..The Flat cable from laser scanner assm to DC controller is very short & narrow, while connecting it to DC board little bit it will come out at scanner assm PCB, remove upper portion up to laser scanner assm refix flat cable both ends of DC & laser pcb. fix all back & try.. I hope it will resolve the issue.. Best of luck...
Sep 27, 2011 | HP Laserjet CM 1312NFI Color Printer
Hi, i have problem with my hp color laserjet 5550 printer.it saiys printer error 59.c0
59.XY A printer motor error has occurred.
(X=C=developing disengaging motor rotation error)
(Y=0=no color/black)
Developing disengaging motor error
1. Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2. Replace the developing disengaging drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Jul 29, 2011 | Office Equipment & Supplies
I have a hp cp4005dn on a network. The prints have color repeating dotts . I have change the toner cartidges and transfer belt. I still have issues.
Calibrate the printer after replacing the ETB.
Full Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller, the ETB,
the drum drive motors, the drum drive gears, or a laser/scanner. Full Calibrate Now includes theQuick Calibrate routines and adds Drum Phase Calibration and Color Plane Registration. Full
Calibrate lasts for about four minutes.
1. Press Menu to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight FULL CALIBRATE NOW.
7. Press to select FULL CALIBRATE NOW. Wait for the printer to calibrate.
Jul 15, 2011 | HP Color LaserJet CP4005dn Network Printer
Colors are wrong. Cartridges say I have plenty of toner in each of the 4 ...but when i print the colors are not right. I did a color test and the yellow is barely visible. How accurate are the sensors that...
Each cartridge has a "memory tag" that keeps track of the cartridge use. It is highly unlikely that all 4 memory tags are bad. Are you using HP cartridges?
Have you calibrated the printer? Do a full calibration.
It is possible that the DC Controller is bad. Each of the "memory tags" reads and writes to the DC Controller. The DC Controller also determines which colors get printed. Have you changed the ITB (Intermediate Transfer Belt)?
Mar 31, 2011 | HP CP3525N Color LaserJet Printer
I have a docucolor 12 and x12 fiery. I am trying to calibrate from the fiery. It will printer calibration page, but it can't measure scanner. It comes up with check scanner cable connection. I have tried...
You should have a color separation guide with small gray scale from Kodak. You put the gray scale and the calibration sheet on the glass and follow the instructions from the fiery display.
Jan 02, 2011 | Xerox DocuColor 12 Color Copier
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
Calibrating Doc 12 without a platen
I am to take it that the Platen cover is missing? If this is the case what you need is Ledger (11x17) or just bigger, bright white paper. Make sure that you use about 6-8 sheets (stacked) on to of each other. Place your color calibration test page on the glass and then lay the sheets over the calibration sheet. This should work as well as the platen white back.
Jan 04, 2009 | Xerox DocuColor 12 Color Copier
Very Light Printer on HP Color LaserJet 3500
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
hope this helps
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
High Contrast in Printing Photographs from DC-12
sir
u do one thing press 0+ start & go to max setup
trc adjustment press start u can get a3 print
next trc toner concentration start
ofter u can get some defference
Dec 11, 2008 | Xerox DocuColor 12 Printer
My HP laser jet 3500 color printer documents look horrible
Hi marsha_smith:
Run this program and let me know if this work for you ok.
pdouglasss
Calibrate Now
Dec 03, 2008 | HP Color LaserJet 3500 Printer
Xerox DocuColor 12 Printer Logo
152 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
