Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load washer is giving a code 3E the machine is noisey when trying to spine after waching the spiner come on, starting to spin but not getting it to full speed, the moter cuts of after few second it tries again, and the moter is noisey
  • Maytag Master
  • 19,396 Answers
3E means no tach sensor signal from motor.
Try first tripping the circuit breaker or disconnecting the power cord to reset the code. If that does not help, then the repair is carried accessing motor and checking motor , hall sensor and wiring.
Here a service bulletin illustrating the repair procedure.
If for some reason you need to test the motor, you will need to read Ohms at motor contacts. There are two set of contacts. Ohms between three of them in one group should be all around 11 Ohms(pink purple white), while the other group must return 2.9 Ohms(red blue white).
Also ensure that the drum is not stuck.
Here all parts and diagrams: MAH5500BW
Posted on Sep 15, 2010
What's your problem? I am getting a 3E code during wash and the machine stops
3E == overcurrent detected at the motor.
Open the control panel, there should be a tech sheet in there that explains how to put the machine into service mode (press chime and extra rinse keys for three seconds) and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes... and lots of other stuff that'll help you track this down.
You can also go ahead and check out the windings on the motor. Unplug harness connector and test from wire insertion side.
Pin #1 and Pin #2 of CN9 == 11.6 ohms
Pin #1 and Pin #3 of CN9 == 11.6 ohms
Pin #2 and Pin #3 of CN9 == 11.6 ohms
Nov 13, 2012 | Maytag Neptune MAH5500B Front Load Washer
What is the error code dS for Neptune Maytag Washer MAH8700AWW?
Please advise me on any recalls and technical information involving error code 3E during a wash load, which appears related to be a faulty control panel. My machine is always shutting down each time it reaches the rinse cycle. Numerous consumers have been complaining about this same model at consumeraffairs.com. Replacement of the control panel is expensive at an average cost of 298 dollars and appears to be the corrective action for other consumers with error code 3E. Over current is not being detected at the motor. I'm disappointed with the quality of this washer considering I purchased it in 2005 for over 1,000 dollars. This problem has forced me to use a local laundry mat to wash my clothes. This error code is not listed in the User manual.
Aug 24, 2010 | Maytag MAH8700A Front Load Washer
Code 3E
what does 3E mean on a
Apr 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
What does a 3E error code mean? i have a maytag
Trouble shooting guild for this machine indicates this means Motor Failure. Over current is detected
Feb 08, 2010 | Maytag MAH8700A Front Load Washer
Cycle stops 3E code appears
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Thanks!
mannu_rakesh
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error code 3E Maytag washer
it overheated... turn it off, wait 10 minutes and take out some clothes
Aug 31, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag front loading washing machine
3E = Drive system is not working correctly. Bad windings, speed sensor, wiring connections or Control Board.
Jun 12, 2008 | Maytag MAH2400A Front Load Washer
Maytag washer 3e fault code
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board.
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
Error code OE does not finish whole cycle
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Oct 11, 2007 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
199 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
