Question about Kenmore Sewing Machines
My kenmore model 3851516000 got stuck in reverse, upon starting to take it apart a small piece came flying out. Am quite savy and would like to fix myself but can't seem to find any interior drawings of my machine.
    Genius:
  • 1,788 Answers
Go to searspartsdirect.com for Sears and put your model #in and they usually have a blow up diagram of the sewing machines. Try that, it should help you. If, you like my suggest, please rate me.
Posted on Sep 15, 2010
I have a Kenmore sewing machine, model 158.16800 and I need to disassemble it. I've removed the screws on the bottom and it still won't come apart. The case is metal.
A parts diagram may be helpful:
Model 15816800 KENMORE KENMORE SEWING MACHINE Parts
I suspect there may be some other bolts from the top that fasten to the base.
However, given that your machine may have seized (is there brown gunk inside the machine?), you may be able to address the issue without taking the entire machine apart.
Wheel on right side that controls the needle up and down is very tight...
May 23, 2017 | Kenmore Sewing Machines
Kenmore 385.1500 sews only in reverse. it is stuck in reverse sewing.
The reverse mechanism lube us going bad. It is accessed from under the machine under the free arm. Usually indicates that the machine is due for a service and oiling. It shouldn't be a problem to get it done at a good sewing machine dealer/store.
Nov 15, 2016 | Kenmore Sewing Machines
Model 158.17550. Where does the little metal piece under the throat plate go?
Kenmore 158.17550 Sewing Machine Tutorial - YouTube
? 25:01
https://www.youtube.com/watch?v=xlPQZ9jmR9c
Apr 2, 2014 - Uploaded by Marianne D
Kenmore 158.17550 Sewing Machine Tutorial .... Why is myneedle hitting something on the plate when I try to start sewing I am getting ... Tweezers work wonders for finding small pieces in the tiny spaces you have to work with. ... I recently purchasedmodel 158.162, Pressure foot will not adjust, currently ...
Nov 25, 2015 | Kenmore Sewing Machines
How do I fix my kenmore sewing machine. Model # 385. 1960180
Consult your manual, the Troubleshooting section. It should explain what the Code 5P means and how to correct it.
Aug 11, 2015 | Kenmore Sewing Machines
My kenmore sewing machine is stuck in the reverse mode
The feed assembly is starting to seize. You will have to take it in to be serviced
Jan 04, 2015 | Kenmore Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
FOOT PEDAL REGULATOR STUCK "ON"
I dont know about the Singer, but I frequently get this on older Bernina models. The foot controller has a suppressor capacitor across the regulator and, on the Berninas, these capacitors fail with age, mainly because they were not specified with a high enough operating voltage for UK markets. Depending upon model, this component might be separately wired directly across the switch contacts or might be on a small circuit board. It is usually rated at 250V - I now routinely replace these with modern parts rated at 1000V and never have returns.
Jul 01, 2012 | Sewing Machines
Putting back the pieces of bobbin case on Kenmore Mini Handi
This is for front loading bobbin..........
The Shuttle hook will look very much like this, and marries this to the "half moon" of the fixed shuttle.
The retaining collar ring that holds it all together has a plate like protrusion (like bull horns), this faces to the top and to the back.......there should be a small lug (or two) with corresponding small hole or slot on the fixed housing (hook race) that locates the ring tightly in the correct position.
There should be 2 swivel arms (black plastic at 4 o'clock & 8 o'clock)) that move to hold the whole thing together by clipping onto a small lug on each side of the ring.
If you tip the machine 30 degrees on its back while you do all this, it makes the process easier, as things are less likely to fall out.........support the back with a soft object for convenience (tissue box, pillow etc)
The bobbin case goes in after the housing is assembled, if you try to do it first, it will prove more difficult.
If this is not quite accurate for your model a photo of the bits would be helpful
Feb 27, 2008 | Kenmore 11206 / 11306 / 11506 / 11606
Handwheel is stuck
NEVER force a newer model machine. Everything inside is plastic and WILL break. Remove the needle, bobbin, bobbin case, and unthread the machine. See if the handwheel turns. If it doesn't, several things could be wrong. The lower end machines won't have belts to come off, they will be fully gear driven. If it is a better machine, it might be a belt problem. Small pieces of thread could be stuck in a gear mesh somewhere. A gear could be broken. It is possible for a gear to break on the first use.
Dec 01, 2007 | Kenmore 11206 / 11306 / 11506 / 11606
Sewing Machines Logo
99 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
