Need to know btu of rhem raka-024jaz Thanks
    President:
  • 1,515 Answers
Hi, this is a Rheem 2 ton unit. For each ton of cooling, there are 12, 000 btu's. So your model number is a 024, that equals 24,000 btu's of cooling. Please don't forget to rate me on this. Thank you.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Posted on Sep 15, 2010
I have two units, Rheem 10 seer Model RAKA 030jaz Model RAKA 024JAZ Technician says both need to be replaced, bad compressor. Can I go with in large system or can I replace compressors in each? House is...
The probability of interconnecting two separate duct networks designed to properly distribute proper air flow with their own air handlers is remote. Is it possible?? Yes. Is it going to work perfectly ?? No. Even if it did, the noise level on a ten ton air handler would be very undesireable in a residence.
As a matter of fact, it may not even be possible depending on how the structure is laid out. A two story with a system in the attic and one in the basement isn't going to interconnect easily for instance...
Mar 11, 2015 | Heating & Cooling
COmpressor not working
Check the capacitor, if it is bulged out it is obviously bad, but I have replaced many that were hard to see whether the top was bulged out or not. If you take the access panel off (should be in the same area as the contactor you were manually pushing in) you should be able to see it. I have only had luck buying them at my HVAC supply houses (usually under $10) You need to make sure to get one that has the same MF as the existing one, if you take it with you someone should be able to match it. Be sure to discharge the capacitor of any stored electricity before disconnecting it (I would recommend calling in a professional HVAC tech if you are unfamiliar or uncomfortable at all with this procedure)
May 13, 2014 | Carrier 38CKC036 Air Conditioner
Rheem RAKA-060JAZ trouble question
pls check for compressor shorting and relay issue in pcb
Oct 12, 2013 | Heating & Cooling
What evap coil can be efficiently used with a 10 seer rheem raka-024jaz condenser
Hello, if the outside condenser is 2 ton than the inside evap coil should be 2 ton aswell. There are 12,000 btu's per ton and the number 024 in the model # represents btu's per ton so you have a 2 ton unit.
Jun 25, 2012 | Heating & Cooling
Rheem RAKA 037 JAZ
When power is applied to the motor try spinning the fan blade with a small object such as a stick, if this gets the motor going than the capacitor is faulty and must be replaced. The capacitor is located in the outdoor unit.
Jun 21, 2012 | Heating & Cooling
Rhem 1 crashes when trying to go forward to the tower.. i have vista, and having trouble downloading the patch.. and the patch requires money and membership.
I had this problem too. There's a patch at "http://www.rhem-game.com/support/index.htm". I updated Quick Time. Windows also asked me to uninstall and reinstall Adobe Shockwave player twice. I've been playing a couple of days now with no more problems but I do save before I get to that spot.
Feb 01, 2011 | Computers & Internet
What size ac ?
The condenser is 2 ton or 24 thousand btus.
Mar 08, 2010 | Heating & Cooling
Rhem 2 graphic card
the red x popps up and game freezes on Rhem 2.
May 08, 2008 | Computers & Internet
Heating & Cooling Logo
353 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
