Question about Raymarine 45 Stv Satellite Tv System
Raymarine 45 STV unit will not maintain tracking, it cycles to search every 20-30 seconds. I have checked connections and there is no outside obstruction, also checked for correct setup.
Parts for Ray54
Sorry.
Replacement cords for the Ray 54 are no longer available according to the Raymarine support forum. Here's the link:
-Steve
http://raymarine.ning.com/forum/topics/ray-54-replacement-microphone-cord
Jan 28, 2014 | Raymarine Ray54 Vhf Marine Radio Dark Grey
Bad compressor or bad capacitor??
Look at the capacitor. if it is leaky or swollen it is most likely bad
Sep 12, 2009 | Ruud UBHC Air Conditioner
TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MINUTES.SEEMS TO COOL FINE MAINTAINS 38 DEGREES, OTHER TRUE COOLER WE HAVE DOES NOT DO THIS...ANY SUGGESTIONS?
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
May 03, 2009 | True Refrigerators
Raymarine st8002 wired to furuno
The st8002 is not compatble with rs232 data. You need to supply it with nmea 0183 data. You will need to wire it to the "NMEA port IN" on the pilot to NMEA out on your Furuno and turn on the mnea sentances "out" on your Furuno. You will need to turn on at least the following sentances GGA GLL RMB RMC.Hope that helps.
Apr 20, 2009 | Raymarine St8002 Smartpilot Autopilot...
Raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
Outside unit not working
If the heating and cooling is working O.K. and maintaining the proper temperatures it is possible that your outside unit is in its off cycle. If the inside unit is running and the outside unit is not with an elevated temperature inside check the power supply to the outside unit. Most units have a disconnect located near them. Check the disconnect and make sure it is set to the on position. Listen for a hum noise at the outside unit which could indicate that the control power is being supplied to the contactor.
Jun 15, 2008 | Samsung AS18A6RB Air Conditioner
Ray45vhf
Hello Billyboy5625,
It looks like the mounting bracket for this radio is available on the manufacturer's website at http://www.raymarine.com/.
Click Customer Support > Find Parts and then search for "Ray 45." The mounting bracket and installation kit both show as available.
Best regards,
Ken
Go Ahead. Use Us.
May 17, 2008 | Raymarine Ray45VHF (53 Channels) 2-Way...
C120
You might try downloading the latest C-Series update from Raymarine's site. It is version 4.26. You can get it on ther site here:
http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=1037
Even if it is identical to the software in there now, the act of actually reflashing the software may get you up and running.
Dec 29, 2007 | Raymarine E120 GPS Receiver
RayMarine sl520 constant re-boot
Double-check that the unit is getting adequate power to it (at least 10.6 V DC.
Otherwise, Raymarine is probably going to need to look at this one as the CPU in it may be defective.
Dec 04, 2007 | Raymarine SL520 GPS Receiver
Raymarine 45 Stv Satellite Tv System Logo
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
