Question about Amana Refrigerators
Amana model #tr25vl and serial # 9701127419, ice maker valve keeps getting stuck in open position which floods freezer . This has now happened 3 times in last 2 weeks .
    President:
  • 1,218 Answers
Good day,
One of 2 causes. The valve sticks in the open position and won't close, or the ice maker electrical circuit tells it to keep filling.
99% of the time it is a defective water valve located on the back bottom of the machine. Changing it is basically a nuts and bolts job. Fairly easy.
If however the problem resurfaces you would need to replace the ice maker but since it is common practice to install a new valve when installing a new ice maker, it's really no loss.
Posted on Sep 15, 2010
Ice maker not making ice
Check and see if a cubes or cubes are stuck in the ejection fingers. If the ice mold is full try cleaning the bottom coils. If the ice mold is empty check the water valve solenoid. Most times both the ice maker and water valve gets replaced at the same time. Nothing inside the ice box controls the ice maker. It does it all itself all it needs is for their to be 35f in the freezer or better.
Apr 06, 2014 | Amana ARSE66MB Side by Side Refrigerator
I have an admiral American fridge freezer. The ice maker is continuously leaking water if the power is switched on as though a switched on. How can I stop the water ?
To verify if its the valve or the ice maker the easiest way would be to unplug the machine and then turn the water on. If the water stops, then the ice maker is bad and is continuously applying power to the valve causing the flood problem and should be changed. If the water keeps on coming out then the valve is bad and stuck open and should be changed.
Jun 04, 2012 | Admiral 26 cu. ft. Side-By-Side...
The ice maker just stopped making ice
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 18, 2011 | Amana AFD2535FES Stainless Steel Bottom...
Amana, bottom freezer, Model No. BX21TW, MFG No. P1196515W W, Serial No. 9804248558, ice cube maker water flow exceeds the capacity of the ice maker and excess water floods the ice cube tray, forming a...
Sound like your water pump is stuck open just follow the water line at the back of the fridge and you will find the pump .Change it out and you should be fine
May 26, 2017 | Refrigerators
I woke up this morning to a flooded kitchen due to the ice maker, in my Amana refrigerator, not making ice and just pouring out water. What is the problem?
Either the switch in the ice maker is stuck keeping the valve open or the valve has stuck. Unplugging the frig will tell you which it is. If the water stops when the frig is unplugged it is the switch. If it does not then it is the valve.
Eric
Dec 12, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Amana fridge ice maker not working
need to check water valve. probally need to replace valve. not letting water through. if valve is ok then ice maker module is bad
Jun 21, 2009 | Amana Refrigerators
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice maker water wont shut off continues to run even when tray is full
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem. http://www.partselect.com/Schematics/Maytag/AA56-20.gif http://www.partselect.com/Schematics/Maytag/AA56-16.gif
Dec 31, 2006 | Amana ARS266ZBS Side by Side Refrigerator
Refrigerators Logo
64 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
