Question about Cell Phones
Btpx100 bluetooth manual - Cell Phones
I would like a full manual for the JBL xtreme speaker?
JBL Xtreme ' Splashproof Bluetooth Speaker with ... - JBL.com
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.7 - ‎35 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours playtime, dual USB port can link multiple speakers and ... Product Specs & Manuals.
JBL Xtreme ' Splashproof Bluetooth Speaker with Powerful ...
uk.jbl.com > Wireless > Portables
JBL
Rating: 4.8 - ‎36 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours ... http://uk.jbl.com/bluetooth-portables/XTREME.html? ... Product Specs & Manuals.
Jan 05, 2016 | JBL Audio Players & Recorders
User manuals free downloads
Hi. I may be able to help you, but I will need more information. Specifically, which device are you trying to pair to your iPhone? I assume you're talking about Bluetooth, right? You can use Bluetooth devices with your iPhone, including headsets, car kits, stereo headphones, or an Apple Wireless Keyboard.
To specifically answer your question, I would need more information about what you are trying to pair with your phone. Note that the documentation that came with your device (headset, car kit, etc) should contain instructions. Is it a Plantronics that you're trying to pair by any chance?
Also, from the title of your post, it appears that you're trying find free manuals for your iPhone. You can access the iPhone Manual from this site: http://support.apple.com/manuals/
If that link doesn't work for you, just go to www.apple.com, click on the Support tab located in the bar at the top of the screen, then scroll all the way to the bottom of the page and look for Manuals under the Resources column in the rectangular "Support" box at the bottom. From the new page that opens up, select "iPhone User Guide -- For iOS 7.1 software." You can download the manual or simply view it. It is very long! Bluetooth Devices are located in Chapter 3: Basics, page 35. BUT, the manual doesn't really tell you anymore than what I've listed below.
Here are some basics, if that is all you're needing:
Turn Bluetooth on. Go to Settings > Bluetooth.
Connect to a Bluetooth device. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. See the documentation that came with the device for information about Bluetooth pairing. (For information about using an Apple Wireless Keyboard, there are different instructions.)
iPhone must be within about 30 feet (10 meters) of the Bluetooth device.
More basic instructions are here:
Return audio output to iPhone. Turn off or unpair the device, turn off Bluetooth in Settings > Bluetooth, or use AirPlay to switch audio output to iPhone. See AirPlay on page 34. Audio output returns to iPhone whenever the Bluetooth device is out of range.
Bypass your Bluetooth device. To use the iPhone receiver or speaker for phone calls:
Answer a call by tapping the iPhone screen.
During a call, tap Audio and choose iPhone or Speaker Phone.
Turn off the Bluetooth device, unpair it, or move out of range.
Turn off Bluetooth in Settings > Bluetooth.
Unpair a device. In Settings > Bluetooth, tap next to the device, then tap "Forget this Device." If you don't see the Devices list, make sure Bluetooth is on.
Aug 06, 2014 | Apple iPhone 5c
Manual for Auvio Bluetooth Speaker
My Bluetooth speaker's light for the Bluetooth (middle light) blinks rapidly, alternating blue and red. Any ideas?
Jun 10, 2013 | AUVIO Bluetooth Portable Speaker
I dont find Bluetooth
Check to make sure your computer is bluetooth capable. Read the manual or go to the manufacturer's website an find the manual. Just because you have wireless internet does not mean it has bluetooth.
You can always purchase a bluetooth adapter that plugs into the usb port to make it able to use bluetooth.
Mar 22, 2012 | Acer Aspire One D257 Netbook
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Can't pair bluetooth with Samsung sgh-a737
the default pass key for all bluetooh phones and devices is 1234 or 0000 try out both till the device connects
Jul 28, 2009 | GE Bluetooth In-ear Headset Wireless...
Motorola H550 Bluetooth Headset
Here is the user manual for the bluetooth headset.
User Manual
Pairing with the LG will be similar, your bluetooth settings will be under settings and tools, and either under "bluetooth" or "connections".
Dec 22, 2007 | Motorola Mobility H550 - Bluetooth Headset...
LG Bluetooth HBM -500 Passcode for pairing
I HAVE LOST MY Bluetooth H500 Manual, can you assist with passcode.
Dec 11, 2007 | Motorola Mobility HS850 Consumer Headset
Cell Phones Logo
217 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
