Question about Sony Ericsson K750i Cellular Phone
@mic problm whay we finde 1.2 k resistor - Sony Ericsson K750i Cellular Phone
Tractor cab does not blow hot air when turned to heat
Low on coolant/ heater core clog up....(electrical) Resistor for the blower/fan (if this the problm it will still work at full blast)/fuse for the fan blower,theres 2 , one that goes to the resistors and your 1,2,3 bliwer setting and the othet on that handles the 4bor last setting, hope this helps
Dec 17, 2016 | Cars & Trucks
My astatic d104 mic squeals
like a pig it does . get it as far from the speaker as you can and if your radio has mic gain turn it down to about half . That should take care of it,but if it doesn't there is another way . You can change mics or open it up and solder a 4700 ohm 1/4 watt in line with the audio wire then solder a .001 waffer cap to one end of the resistor and another to the other end then solder them to the shield wire . ________________x________x________________ audio
l .001 l two .001 caps
l l
------------------------1---x resistor x _______________ shield
Apr 10, 2014 | Astatic Road Devil RD104E CB Radio
When i keyup my d104 mic on cober 148 gtl ihear feedback squeal.but the d104 work good cobera 2000 gtl
try to keep the mic away from the radio speaker.check to see if its turned up to high.check your mic gain to make sure its like 1/2 open.If these fail then you could solder two 0.001 ceramic disc capacitors from the audio to the shield wires about 3" apart.then on the audio wire in between the 2 caps solder a 4700 ohm 1/4 w resistor.this should work.
Nov 09, 2013 | Midland 1001Z 40-Channels Base CB Radio
Karbonn k447 mic problm
if it stopped working= its down and u'll need to replace it
if it works sometimes= get it repaired
in both the above cases
Dec 08, 2011 | Cell Phones
I hv lost driver for enet webcam(usb)with mic.pls solve my problm
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver hope this helps
also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
hope this helps
http://www.filebuzz.com/findsoftware/Universal_Software_For_All_Webcams/1.html
http://www.filebuzz.com/findsoftware/Webcam_Driver_For_All_Webcams/1.html
May 20, 2011 | Computers & Internet
Tr51 gets hot
Do you have a "swing kit" or a "swing diode" installed?
This could also be called an NPC ("Negative Peak Clipping") Modification. There should be a 1/2 watt 100 ohm resistor attached on the unbanded end of the diode. If it is a "Kit", It will not have a 100 ohm resistor and can cause TR51 to overheat during long transmissions.
You may want to remove the diode or kit if you have one in there and, as a better choice, change R238 (near VR13) to a 220K ohm resistor.
That will give you Killer loud audio with a stock mic. You probably won't be able to use a pre-amp (Power) mic after changing R238 to a 220k ohm.Back down the carrier power to 3 watts and watch the modulation get violent!
Apr 07, 2010 | Galaxy Radios DX 77HML Base CB Radio
Feedback problems with astatic echo boards
This is a classic indication of a lost shield or ground connection in the mic circuitry. Double check these connections for good contact in the mic *and* the plug at the other end of the cable.
Check the grounding and SWR or "match"of the antenna system, too. A poor SWR (greater than 1.5:1 or 2.0:1) can cause the reflection of RF back to the radio. Modifications can increase sensitivity of the mic to this unwanted RF.
Sep 29, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
SE2200a rapid signal drop off
I had the same problem with my Saffire: the phantom power voltage quickly drops when switched on, causing the mic to cut out. This problem is common in older Saffires, and is well known to Focusrite support (a modification in newer-production units solves the problem).
The problem is that a tiny 100 ohm surface-mount "chip" resistor in the phantom power circuit fails due to insufficient power-handling capability. (This is "R196" in the phantom circuit.)
The fix is to replace the "chip" resistor with a "normal" 1/2 watt metal-film resistor (with wire leads), mounted upright on the circuit board.
I replaced the resistor myself, following directions (and photos) sent to me by Focusrite Tech Support.
The procedure is somewhat fiddly (a Swiss watchmaker could probably do OK). If you've never soldered before, DON'T EVEN TRY THIS, and if you've never worked with surface-mount components, I would ask your electronics-hobbyist buddy to do it for you.
Here is the procedure sent to me by Focusrite:
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SAFFIRE PHANTOM POWER MODIFICATIONS
Dismantling the Unit
Remove the 7 screws on the rear panel.
Remove the 4 screws on the underside of the unit.
Lift away the metal cover.
Remove the 4 small black screws securing the MIDI In/Out sockets.
Remove the single screw securing the S/PDIF In/Out sockets.
Remove the two screws securing this PCB to the chassis.
Gently pull the PCB away from the rear panel and move it through 90 degrees towards the front panel.
Place the unit on its front and support the PCB with some suitable non-conductive item.
Modification Procedure
All the components mentioned are located in the same area on the same PCB (see photo).
It is best to remove the coil and capacitor (as shown in the second photo), as this gives easier access to the components.
Remove R196 and measure its resistance. If it does not measure 100 ohms, replace it.
Use a conventional type (100 ohms metal film, .5 or .6 watt) mounted upright as shown in the photo. Before fitting this resistor, check that the three zener diodes DZ11, DZ12 (22v) and DZ9 (3.3v) are OK and have not shorted out. (Diodes are 500mW, 5% tolerance)
Testing units for Phantom Power problems
Connect a condenser Mic or suitable dummy load* to Channel 1.
Engage +48 switch.
Measure the DC voltage between XLR pins 2 & 1 on Channel 2 Mic Input XLR.
Faulty units usually read around +28Vdc and the voltage gradually drops.
Good unts will measure +48Vdc +/- 0.7Vdc.
* Dummy Load for testing: Solder a 20,000 ohm resistor between pin 2 and pin 1 of a male XLR plug and another 20,000 ohm resistor between pin 3 and pin 1 of the same XLR plug.
Here are the photos:
My Saffire has worked perfectly since I replaced the bad resistor.
Good Luck!
Ken
May 04, 2008 | SE Electronics SE2200A Professional...
D-104 Silver Eagle Mic Squeels
Hi, usually when they refer to putting a cap in, their talking about adding a .01mfd disc cap to the white audio lead wire up inside the bottom of the mic. Just follow the cord into the bottom of the mic, by taking the bottom off. find the white(audio) wire where it fastens to either the board or the terminal strip. Just unsolder the white wire and add the cap and resolder the other leg of the cap back where the white wire was removed. Some people even use a cap and resistor combo. Sometimes using a .001 cap from the audio line to ground then a 4700 ohm resistor will work in extreme cases.
http://www.qsl.net/wa2mzf/d1044.jpg
You can experiment with different combo to see what will work for you. Hope this helps you out, let us know,,, Mechanic
Feb 17, 2008 | Radio Communications
Sony Ericsson K750i Cellular Phone Logo
73 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
