Question about Maytag MDB5100A Dishwasher
The lower water dispensing arm will not rotate. There is no binding and water is being applied. I do not know if my water volume is great enough to spin and discharge soap water.
  • Maytag Master
  • 43,501 Answers
I would replace the spray arm, there is probably dirt built up inside it...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 15, 2010
Kitchenaide rinse dispenser in dishwasher doesn't work. White soapy streaks on plates
Confirm that lower washarm is rotating. Initially check by rotating by hand. Second mark arm position turn on unit stop and heck arm position.
Listen very carefully and confirm arm is turning. It is often found debris clogs the lower arm jet preventing the arm from turning.
Also check the water level in washer sump. Low will also keep the arm from rotating.
Hope this helps.
Jun 29, 2017 | Dishwashers
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
The soap doesn't dissolve and sometimes the plates are still dirty.
Start dishwasher. Stop after a minute or so. Check the water level in the tub. On a older model I would expect about 2 inches of water in the tub. About 1/2 inch or so below heater.
If water OK than I assume you can hear the pump running.
If pump running and enough water than I would assume a blocked wash arm.
  • First rotate by hand and make sure that it doesn't bind or interfere with rack.
  • Check carefully the holes at the ends of the arm looking for debris that collects. Seeds and such love to collect at the tips preventing the jet of water that provides the rotation force from escaping. Use small tweezers to grab debris and pull through hole
  • Blocked water return screen. Look for clear plastic etc that covers the return of the water to the pump sump.
  • Place small cups right side up in upper and lower rack. Cycle machine for a minute or so. Confirm cups are filling with water!!
If all checks OK than try running water at sink for several minutes to confirm water is very hot. Start cycle knowing inlet water to dishwasher is hot. Evaluate results.
Dec 09, 2015 | Kenmore Dishwashers
Dishes are cloudy and have soap residue. Have cleaned upper &lower spray arm often, as good as posible (find holes plugged). water level & temp. seems normal . Water intake screen appears clean
Clean the spray arm jet holes if they are blocked. Check whether you have filled the rinse-aid dispenser.
Check whether arm turns freely when rotated by hand manually.
May 26, 2010 | Maytag MDB9600A Jetclean II Built-in...
The bottom washer arm does not turn or squirt water
Hi Matt.
The lower housing underneath the lower wash arm may still have something blocking the water passages.
If the spray arm is clean and it freely rotates try lightly pressing down on the wash arm and then rotate it. Your checking to see that when water is applied to the spray arm it forces the arm down against the lower housing tower and hopefully does not lock up. If it does lock up while pressing down and rotating obviously you need to find out what the cause is.
You may have to remove the lower wash arm housing and clear the debris from the water passages. Once the passages are clear it should work fine.
Thanks for using FixYa,
Kelly
Apr 09, 2010 | Viking DFUD042 Built-in Dishwasher
Kenmore dishwasher we use new finish detergent and the little soap pouches do not dissolve.
DOES THE SOAP DISPENSER DOOR OPEN, IF SO THEN EITHER THE WATER FROM SPRAY ARMS NOT REACHING THE DISPENSER, POUCHES IMPERVIOUS TO WATER OR REQUIRE HOT WATER AND WATER IS NOT HOT ENOUGH. CHECK THAT THE SPRAY ARMS ARE NOT CLOGGED WITH DEBRIS. ALSO COULD BE SOME UTENSIL KEEPING THE SPRAY ARMS FROM ROTATING.
Mar 09, 2010 | Kenmore Dishwashers
DISHES ARE NOT COMING CLEAN BYPASSED THE DOOR LATCH TO WATCH CYCLES,LOOKS LIKE THERE IS NOT ENOUGH WATER PRESSURE TO ACTIVATE THE WATER TOWER AND ROTATING ARM?WATER PUMPS OUT BUT NOT ENOUGH TO MAKE THINGS...
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 24, 2009 | Dishwashers
Soap still in dispenser even though the dispenser door had opened
Be sure that nothing on the top rack is interesting with the door opening. Next place in unit in the wash mode. Let it fill and start washing. Open door and you should have water standing just below the lip on the wall of the unit below the lower rack. If so you are full of water.
Next is to ensure your washer rotating arms are not plugged. The very end of the upper and lower arms spray on the door to wash the soap out. If the are contaminated you will have to remove them and clean the out.
Lastly, the dispenser is operated by what is called a WaxMotor. Simply put it is a small amount of wax contained in a tube with a piston inserted. There is then a heating element around the tube. When it appmys heat the wax expands and pushes on the piston which I turn releases the door to be opened by its spring.
These can go bad and open too late in the machines cycles. It is located in the door and unless you are quite handy I would recommend a qualified technician.
Jan 01, 2018 | Maytag 24 in. PDC3600A Built-in Dishwasher
Maytag MDB3100 Soap Dispenser Problem?
Remove each arm and inspect the small spray holes for plugging. Use a vacuum in the center hole and poke out each plugged hole. Unless your vacuum allows wet pick-up, make sure the arm is dry first. Try using a capsule type of detergent instead of liquid. You might have to tear down the lower spray arm assembly to the deck to clean the large screen which may be plugged with water/food deposits. Use hot water, detergent and white vinegar to clean the screen. Hope this helps!
Jun 12, 2008 | Maytag MDB3100 Dishwasher
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Maytag MDB5100A Dishwasher Logo
65 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
