Question about Car Audio & Video
I have a 6 CD changer in my 2004 Avalance...There are 5 CD's stuck that won't eject or play and once in awhile it attemps to "initialize" but nothing ever happens.
  • 944 Answers
HI rick,
This problem occur due to various reason and try all the solutions.There will be a need to remove the cd changer apart and to do some testing.
1)If more than one CD loaded but in jammed fashion will not allow the eject button to work.When you click eject button do you hear the motor rolling sound.
2)Check for loose connections in wire and short circuit in the player.Use multi meter to test it.Test on the solders to.
3)There will be a small hole in most of the Cd player.Use a pin into it and push it in and the cd rotater wheel will open the player.
4)Check for the fuse not blown away in the player.
5)Just remove the power supply let it be for some hours idle not connected to reset the unit.
6)There will be a spring loaded which will be jammed that needs to released properly.
7)Please provide the brand name and model no so i can provide you more help.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 15, 2010
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
Cd changer stuck
There is a small pin hole on the door of most changers. straiten a paper clip insert in the hole ratchet back and forth on the gear in side to open.
Sep 21, 2014 | 2004 Nissan Murano
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
Six cd changer with 6 cds stuck inside, none will play and message appears no cd, or cd error,or eject error in a 2004 ford escape
Ok this may seem barbaric but it worked on mine.......Hit the top of the stereo a couple of times and see if it corrects the problem.
May 30, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Rockford Fosgate cd changer
I have the same problem with the 2006 sentra
May 28, 2009 | 2005 Nissan Sentra
Cd stuck, press eject, little sound, does not eject, 2004 Dakota
try taking this apart and removing your disc, then once put back together it should stop malfunctioning :)
hope this helps
Feb 16, 2009 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
Envoy 2004 cd player
I had same problem with a 2005 Envoy in Jan '09. I took it to the ex-GM dealer. He said he'd try. The unit would only play using radio.
Mechanic took unit out of dash, and top off of unit. Ejected CD bu moving the eject mechanism. Replaced top and unit.
Works and plays cds. Cost $25.00 And i tipped the mechanic $10.00 for his knowledge.
Jan 30, 2009 | 2004 GMC Envoy
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
My 6 disc changer in my Ford 500 won t Eject or play
well i don't have a 6 cd changer but i have had a few problems like that and all i can tell you is using something to unjam as soon as you hit the eject has been working just fine for me .......hope it helps a bit
Jun 27, 2008 | Car Audio & Video
Cd stuck
All You Have To Do Is Unscrew The Radio And Take It Apart. Take The CD Out And Put It Back Together Again. This Solution Worked Like a Charm For My Stereo.
Mar 15, 2008 | Jeep AM/FM Cassette with CD Changer...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
