Question about Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23724
I have a Kenmore 16 cu ft upright freezer purchased around 1994...maybe even earlier. We recently defrosted it and after turning it back on, it worked for less than a day and then quit. When you turn it on, it sounds like it tries for about 30 seconds, then shuts off. I have done absolutely no maintenance on this unit..I am kind of handy but know nothing about where to start.
  • Kenmore Master
  • 1,711 Answers
You can do the first aids which might help before a technician check it out.
You can clean the condenser which is on the back of you refrigerator from any dust with a brush and or blower or a vacuum cleaner this must be done once a year for better performance.
So if you are lucky and is not something very serious the above tips can help and sometimes can solve your problem
If the above does not help then their many possibilities for your problem like
Problematic thermostat, can not be fixed must be replaced.
Freon leak for which, authorised technician with licence can only deal with Freon gas.
Compressor relay or starting capacitor, Evaporator fan, temperature probe and electronic control board are some other possible problems
but all need special knowledge and skills and licence for dealing with Freon gas..
Good luck
Posted on Sep 15, 2010
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Kenmore upright freezer quits working but can restart when the unit is unplugged and plugged back.
check the freezer back wall @ bottom if frosted up 1-bad heater (a-glass tube heater or cow rod. 2-bad times 3-bad defrost senor 4- bad fan motor
Aug 15, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Groaning Kenmore 13.5 cu. ft. Upright Freezer
This sounds like you either have a bad fan motor or if you have ice built up on the inside back panel. It could be that the fan blades are hitting ice built up around it. If so, you will have a defrost problem that will need to be addressed to fix the unit. But to repair it so it will stop making the noise, you can defrost the ice (if present) with a hair blow dryer. This will keep the ice away for a few days. Good luck.
If there is a defrost problem, the heater (located around the coil) is most likely the problem.
Nov 17, 2009 | Kenmore Freezers
Kenmore freezer model 20638 upright 16 cu ft runs all the time
Clean the condenser coil, might be blocked and not able to radiate any heat. Also if the racks are the freezer coils, defrost those to the bare coil/tubeing.
Jun 29, 2009 | Kenmore Freezers
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer has frost in back- frig not coolling
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
Mar 04, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice forming on pipes in back of freezer
you could have a freon leak allowing the pipes to freeze up
Dec 31, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Where do you see the water coming from ?
Jul 21, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Not Freezing, but cold
The thermostat should be a close circuit when requesting cold temps. or when asking the compressor to come on. The exterior surface on some freezers warm when asking for cold inside. Yours has a condenser coil on the back and that should warm when cooling. If compressor is runningit should be wrm if no freon has leaked from freezer somewhere.
The defrost timer should rotate clockwise during the day and give approx. 3 defrost daily or about every 8 hours. Until the thermostat is resolved and asks for a closed circuit the compressor will not come on. Unplug freezer from outlet,remove thermostat wires, then turn the thermostat to its coldest setting and check again. If no closed circuit the thermostat will need replaced first. Hope this has helped you, Sea Breeze
Nov 01, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore 16.7 cu. ft. / 473 liter Upright Freezer 23724 Logo
99 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
