Question about ECHO, Inc. PB-251C Handheld Blower
Got multiple pb620 blowers with same problem all of them start and idle but when u try to throttle them up they die have cleaned carb changed plug checked exhaust and wiring with no luck and echo dealers have been no help every shop i call wants me to bring blower in and let them work on it with 6 of em doing same exact thing im sure it is a common problem with a fairly simple fix any ideas
  • 183 Answers
A very common problem with most 2cycle units. My guess is that these units are 12 to 18 months old, and probably just need a simple carburetor adjustment. Remove the plastic limiter caps from the carb and open up the low side (nearest to the engine) jet about 1/4 to 1/2 turn counter-clockwise. Some of the carbs that Echo uses are not adjustable at all, and therefore the carb must be overhauled with all new rubber or must be replaced. Don't be mad at the shop, that is how they make a living.
Posted on Sep 15, 2010
Troy-Bilt Hand-Held Blower dies when warm and throttle wide open
You reported that most of the items I would've suggested, you have checked...
Good job.
A couple more things:
  • Replace fuel filter, it's in the gas tank
  • Check and clean the Spark Arrestor screen at muffler, when they plug up, it's a major restriction to exhaust gas flow
  • And check and adjust High/Low screws at carburetor, video attached.
  • And clean or install rebuild kit for carburetor
Good luck...
One more...
May 30, 2015 | Troy-Bilt Garden
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
Starts idles for a minute then dies
Have you checked the actual fuel pipes for flow ? You might need a carb refurbish kit. Weak vacuum causes similar type problems.
Apr 05, 2014 | Suzuki Motorcycles
Hello, i have a husqvarna 130bt blower and it will start up fine and will idle fine but dies when squeezing throttle. I replaced gas, checked fuel lines, took muffler off and cleaned, and took carb off and...
Did you clean or replace the air filter?
Did you put too much oil into the fuel?
At idle, it it running roughly at all? If so, you may need to replace the spark plug.
Nov 03, 2017 | Garden
Starts and idles will not run above idle unless choked. Have cleaned carb multiple times new fuel filter new air cleaner and cleaned exhaust screen new plug. Maybe a collapsing fuel line?
Have you tried adjusting the carb? There should be two screws on the carb (hi & Low) turn the hi screw completely until it stops and then start the unit. Let it warm up and then begin to back the screw out until it starts to run smoothly but strong. Once you have it running then put it in full run position (choke) and you should be good.
Feb 19, 2010 | Echo Inc. 44 CC, Carb Certified Backpack...
PB620 Echo Blower will not stay running
check and see if the muffler is plugged and it can't get rid if it's exhaust.
Aug 07, 2009 | Garden
POULAN 200 mph blower. New spark plug last fall.
You will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the carburetor parts are more than four years old, and depending on the use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Jun 15, 2009 | Poulan Garden
Weedeater won't take fuel
You need to remove the carb., disassemble and spay with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), toclean the small portals in carb. Check the small screen. It could have dirt clogged in it. Reasseble and start. If it still doesn't run properly, you will need to buy a carb. kit and replace the screen, needle valve, gasket(s), & diaphragm.
Jim
Jun 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Ryobi PBV-30A Carb problem
I have a rayobi PBV30A petrol trimmer and it keeps dying once you increase the throttle speed runs on idle.
Feb 17, 2009 | Ryobi Garden
ECHO, Inc. PB-251C Handheld Blower Logo
576 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
