Question about Dell 1815dn All-In-One Laser Printer
Currently have a Dell 1815 - keeps saying Front door is open and will not print. Have tried everything - from turning off printer, unplugging, changing toner, etc.
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
Hey, make sure the front door is shut, if it is, you most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS. Good luck!
Posted on Jun 16, 2011
Dell 1815 keeps saying door open when it is not.
The front door switch has gone bad which is part of the High Voltage Power Supply. You need to replace the HVPS (part# WH773). This should clear your problem right up. Iteminc.com has this part and ships same day.
Jun 08, 2011 | Dell 1815dn All-In-One Laser Printer
We are getting error code 004-332 Restart Printer on our Dell 3100cn printer. We have tried unplugging and restarting print spooler but it still come up witht message when we try to print
Hi
This error code on Dell 3100CN occurs when toner cartridges are not seated properly and/or are not properly locked in. Turn off the printer and unplug it. Now, you need to open the front door and pull out the drum. Try moving the carousel and check if it moves freely. While moving the carousel back and forth try adjusting the cartridges. try to unlock the cartridges and lock them again.
Now turn off the printer and turn it on after 1-2 min.s.
Daniel Scott
Jun 24, 2010 | Dell 3100cn Laser Printer
Every time I try to print a paper, it always says that it has a paper jam. I have took out the paper, and did everything it said to do, but it still jams. What should I do?
Usually if it says a paper is jammed, there "is" something in there that got missed. You just have to keep digging until you find it. You did't say if it actually starts to print first, or if it says it right off the bat from the previous print attempt. It may require further disassembly to find the problem, ...it could be something very tiny if a piece tore off when you were unjamming it before. It could also be "mis-feeding" ...reply with a liitle more info if you don't find it.
Jun 12, 2010 | Dell 926 All-In-One InkJet Printer
Dell 1815 dn - bogus front door open message
Sep 08, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1815 All in One Printer Says No Paper When Paper is Full
Most likely the printer is asking for paper in the Manual Printer Feeder (not the tray). Try put paper in the MPF.
CHeers
Sep 01, 2009 | Dell 1815dn All-In-One Laser Printer
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Dell Laser MFP 1815 won't print. Message keeps coming up Jam 2 open rear and front door. Have opened and shut doors repeatedly, restarted printer, tried copying over message but it keeps being displayed....
I had same problem. If you go to rear of printer and open the back door you'll see it is attached to a blue connector. Unattached it so that the door opens fully and then unflap the inside roller assembly. Next open the fuser door and you'll notice a little spring loaded assembly on the inside of the opened fuser door. This is where my problem was. Make sure that the assembly springs back when pushed because part communicates with a sensor on the motherboard. If it doesn't spring back then the printer thinks there is a jam. Mine was stuck but after pushing it a few times it started to work freely again. This was a frustrating problem but that fixed my issue and hopefully it will fix yours.
Jun 04, 2009 | Dell 1815dn All-In-One Laser Printer
Dell Laser MFP 1815 wont print
The printer status showing offline is more then likely a computer issue then the printer. On the printer, use the menu to select "reports" and then select the printer settings report. If the printer prints the report, then the printer itself is working, and it is a communication issue between the printer and the computer. If you are connecting to the printer with a usb cable, then try moving the usb cable on the computer to another port. If this does not work, try deleting and reinstalling the printer.
Sep 25, 2008 | Dell 1815dn All-In-One Laser Printer
Dell printer problem
Sounds like you may need to replace the pick up rollers on the machine.  Without knowing exactly where the jam error happens during the print process, it's hard to say.
Oct 19, 2007 | Office Equipment & Supplies
Dell 1815dn All-In-One Laser Printer Logo
213 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
