Question about Mtd 22" Yard Machine Push Mower
Need spark plug size - Mtd 22" Yard Machine Push Mower
  • 1,631 Answers
Cross thread the spark plug on cub cadet 2135 plub # RC12yc 8 hp what size tool needed to fix plub hole?
Go to any auto parts store and bring the spark plug with you, ask for a spark plug well repair kit for that plug size.
Feb 16, 2017 | Garden
I have a Ford F150 2001. The spark plug blown out of number eight cylinder. I need to rethread it I have a size 16 1.5 mm tap what size insert to use
Demise, Buy the whole Ford spark plug rethread kit, no guessing involved. You can google search for the kit, to get a good price.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ford Spark Plug Blowout
How to Repair Stripped Spark Plug Threads Auto Clinic
Replacing blown out spark plug
Spark Plug Thread Repair REPAIRING FORD TRITON SPARK PLUGS M14x1 25 blown out problem
Amazon com Lisle 65000 M14 1 25 Spark Plug Hole Repair Kit with Deep Hole...
Jun 26, 2016 | Ford Cars & Trucks
2001 Chevy cavalier It's a 2.2 litre 4 cylinder. what size of spark plug socket do I need to replace my spark plugs ? Please advise !!
When you buy the new spark plugs, take one of the plugs and get a spark plug socket to fit. The size may depend on the brand? Try 5/8 spark plug socket. Hopefully the socket for the new plugs will fit the old plugs?
May 14, 2015 | Cars & Trucks
What size spark plug spanner do i need for a toyota starlet
Most spark plugs require a 5/8 deep well spark plug socket..I be more concerned with why one "fell out"
Jun 28, 2012 | 1996 Toyota Starlet
Size spark plug socket wrench for yamaha FZR 1000
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
SPARK PLUG REMOVAL TOOL SOCKET FITS YAMAHA FZR1000 EXUP 1989 1993 eBay
Help Needed Spark Plug Socket Size
Exup1000 co uk Tech FZR1000R
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Jun 10, 2012 | 1990 Yamaha FZR 1000
How do you properly replace spark plugs in a 96 dodge stratus?
pull off plug grabbing it as close to spark plug as you can. Using socket rotate counterclockwise and remove plug. Be careful putting plugs back in and thread by hand first. Then torque as plug box says as it depends on if you have a washer or not.
Dec 22, 2010 | 1996 Dodge Stratus
Can a home mechanic easily change a 1997 Eldorado's spark plugs and wires? Is there anything I need to know - good/bad, hints, etc?; any advice please. I was told this is too difficult to do with...
NORTHSTAR 4.6 ENGINE REMOVE INTAKE MANIFOLD SERVICE COVER FROM THE ENGINE.SPARK PLUGS IN THE VALVE COVER BUT THE SPARK PLUGS NOT HARD TO CHANGE.YOU NEED A LONGER SPARK PLUG SOCKET OR YOU USE REGULAR SIZE PLUG SOCKET USING LONGER EXTENSIONS.YOU NEED SPARK PLUG BOOT PULLER.YOU NEED A UNIVERSAL JOINT.BESURE TO GET PIECE RUBBER HOSE 10 INCHES OR WHAT EVER SIZE PLACE HOSE OVER SPARK PLUGS FOR THE HARD TO REACH SPOTS TO HELP AID SPARK PLUG BACK IN WITHOUT STRIPPING THE THREADS.HOPE THIS HELP.
Aug 05, 2010 | 1997 Cadillac Eldorado
How to change spark plug on lexuse gs300 2003
Hi, You need a new Spark Plugs Spark Plug Wrench Socket wrench Extension (At least 2-3 inch) size 10 socket size 12 socket...
First thing you need to do is find out where the spark plug cover is. Once you figure that out there will probably be size 10 or/and 12 bolts honding it down. Take that off and there you will see sensors connecting to each other and holding the spark plug in the cylinders. Unplug all the sensors and pull out the circular plugs holding the spark plugs down. THey might be a little tight and hard to get out so you're going to need to give it a good tug. Once you pull them out MAKE SURE YOU DONT DROP ANYTHING INTO THE CYLINDERS. You can look down into them and see the spark plugs. Get your spark plug wrench, extension, and socket wrench and stick them down in and push so that the spark plug wrench grabs them. Just simply unscrew the plugs, pull them all out, and then put the next ones in, and tighten them down. Just connect all the sensors, and put the cover back on and you're done. Pretty simple.
Take care
Jul 23, 2010 | 2003 Lexus ES 300
How to change the spark plugs
if its your first time you need a haynes repair manual.you need a spark plug boot puller.you need 3/8 ratchet wrench.spark plug sockets.from size 5/8 to 13/16.you probably need size 5/8 socket.you need extensions different sizes.and universal joints.to reach hard to get plugs.you need torque wrench. and spark plug gap set.
Jul 07, 2009 | 2002 Kia Sportage
How to change spark plugs... 2003 ES300
Hi!
You need New Spark Plugs, Spark Plug Wrench Socket and Wrench Extension (at least 2-3 inch) size 10 socket and/or size 12 socket.
First of all, please check where the spark plug cover is. Once you figure that out there will probably be size 10 or/and 12 bolts holding it down. Take that off and there you will see sensors connecting to each other and holding the spark plug in the cylinders. Unplug all the sensors and pull out the circular plugs holding the spark plugs down. Pull them out and make sure that you don't drop anything into the cylinderes. You can look down into them and see the spark plugs. Get your spark plug wrench, extension, and socket wrench and stick them down in and push so that the spark plug wrench grabs them. Then unscrew the plugs, pull them out and put the next ones in and tighten them down. Just connect all the sensors, and put the cover back on.
Thanks for using FixYa and do rate if found this solution helpful.
Thanks
Rylee
Mar 27, 2009 | 2003 Lexus ES 300
Mtd 22" Yard Machine Push Mower Logo
172 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
