Question about HP Deskjet F4235 AllInOne InkJet Printer
My Deskjet F4235 shows an E in the number of copies box. It will not print but everythings appears to be moving okay. Also, the print cartridges lights keep blinking and I just recently replaced the cartridges. The printer worked fine at first, then just showed the E and wouldn't print any more. Thanks for any help.
SOURCE: printer deskjet 3650
saks
Posted on Jul 10, 2008
  • 73 Answers
SOURCE: HP 6940 color cartridge light will not stop blinking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
I might have an idea why this is happening....The print cartridges might need cleaning...
Follow the steps below to do this....
Step one: Remove the black, photo print cartridge, or the gray photo print cartridge
NOTE:
The black, photo print cartridge, or the gray photo print cartridge is in the right side of the carriage. -Lower the cover of the product.
-If the print cartridge status light flashes, proceed to Step two: Replace the print cartridge.
If the print cartridge status light is off, proceed to Step three: Manually clean the print cartridge.
Step two: Replace the black, photo print cartridge, or the gray photo print cartridge and remove the tri-color print cartridge
- Remove plastic tape from new ink carttridge CAUTION:
Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper electrical contacts.
NOTE:
The tri-color print cartridge is in the left side of the carriage.
-Lower the cover of the product. -If the print cartridge status light stops flashing, proceed to Step three: Manually clean the print cartridge.
If the print cartridge status light still flashes, replace the tri-color print cartridge. If the issue continues, service the product.
1. Gather the following items to clean the print cartridge and carriage:
o Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
o Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
o Sheets of paper or a paper towel to rest the cartridges on during cleaning.
2. Open the product cover, and wait until the carriage stops moving.
3. Remove the print cartridge, and place it on a piece of paper with the nozzle plate facing up.
NOTE:
Clean the contacts quickly so that the print cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
4. Unplug the product.
5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
6. Clean the print cartridge contacts. Do not touch the nozzles.
7. Clean the contacts in the carriage, inside the product.8. Either let the print cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
9. Reinstall the print cartridge.
10. Plug the product back in.
11. Close the product cover.
Good Luck!
If there is anything more I can do for you please let me know if not and the problem is solved please rate it, Thanks, JCE
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: Hp deskjet D2560,incompatible cartridge
pls check your cartridge carrrier.
Posted on May 29, 2009
  • 3278 Answers
SOURCE: F4235 cartridge will not fit in slot
Hello.
Be certain that you are using the HP 60 (CD947FN) Black/Tricolor Ink Cartridge.
If you have the correct cartridge, it should fit and just snap into place.
Hope this helps.
Posted on Nov 13, 2009
Comp-U-Doc
  • 148 Answers
SOURCE: Blinking lights plus E sign for cartridge error -
Look carefully to make sure there is no paper jammed inside. Sometimes there can be a small piece of paper that tore-off in the gears causing a paper jam.
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
Posted on May 11, 2010
Full ink cartridge but won't print or photocopy
some cartridges are dated and printers can read the dates on cartridges try new cartridges it should work then.
Dec 16, 2014 | HP Deskjet F4235 AllInOne InkJet Printer
HP Deskjet F4235
What is the state of your ink cartridge(s)? Dried out perhaps?
For reference, the HP support page is here:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3571316&lc=en&cc=us&dlc=en&lang=en&cc=us
Jan 18, 2014 | HP Deskjet F4235 AllInOne InkJet Printer
HP DeskJet 970Cse cartridges won't move
okay be gentle, but try to move the cartridge box manually from side to side. it's possible that the gears have gotten stripped which is why they won't move even though they are trying to. so i'd try and move them from side to side and see if you can physically move it yourself. like i said be gentle in the chance the gear isn't stripped. good luck!
Feb 09, 2012 | HP DeskJet 970cse InkJet Printer
My HP Deskjet F4235 AllIneOne InkJet Printer cannot print.
Turn off then turn on again. or
Unplug the cable from printer then plug in again.
If the problem persist try to reinstall your driver.
Hope this help
Feb 02, 2011 | HP Deskjet F4235 AllInOne InkJet Printer
`HP Deskjet F380 All-in-One Printer-Scanner-Copier E light is on seeming to refer to an ink cartridge issue. I installed new black and color ink cartridges. Light is still on and printer won't make...
Issue: Print Cartridge light is blinking
NOTE: In addition to the blinking light, an "E" might appear in the Copies area.
Solution
Close the print cartridge door.
Cause
The print cartridge door is open.
Oct 28, 2010 | HP DeskJet F380 All-In-One Printer
Hello.
Hope this helps.
Nov 13, 2009 | HP DeskJet 920c InkJet Printer
Everything prints out pink
Try the head cleaning..This always solves such kind of problems.
Apr 06, 2009 | HP DeskJet 930c InkJet Printer
Red will only print on test page.
So what you need to do is clean the cartridge from the printer toolbox..do all the three steps cleaning..(clean cartridge,prime cleaning,intermediate cleaning)..
once the cleaning is done..try to make a copy..if its still the same..change both the ink cartridge and then try to make a copy..if it resolves the issue then cartridge is defective..if it does not resolve the issue then printer is defective..
Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
I need step by step instructions as far as how to change cartridges in hp deskjet 5440 printer
[This is from HP.com]
Introduction This document explains the basics of installing or replacing the print cartridges. It is for a 5940 which is the same printer design, yours may look a bit different but I copied this from HP at the section for your printer so follow the instructions and you should be okay.
Insert the print cartridges
NOTE: The printer shown below is the HP Deskjet 5940 series printer. Your printer might look slightly different.
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Open the cover c00393707.gif
  3. Wait until the print cartridge cradle moves to the right side of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 2: Remove tape c00393708.gif 1 - Protective tape CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 3: Install the print cartridge c00393709.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Original Page here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00411520&lc=en&dlc=en&cc=us&product=445441&os=228&rule=27868&lang=en
Regards,
Worldvet
Dec 01, 2008 | HP Deskjet 5440 InkJet Photo Printer
Print Cartrige Error
they probably are dried up if they were in storage
Mar 16, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP Deskjet F4235 AllInOne InkJet Printer Logo
214 people viewed this question
Seeker5211
Seeker5211
