Question about Philips Audio Players & Recorders
I have a 20 yr old Philips/Magnavox Apmlifier FA1461 that seems to have a relay problem as it clicks after power on , but then does not power on after click , any ideas where I can get this repaired in toronto Canada ?
4 Suggested Answers
  • 142 Answers
SOURCE: Power On + red LED turns on + but final relay (click) don't come so no sound
Your audio output transistors are shorted and your unit is staying in "protect " mode to protect your speakers from 40 to 60 volts that is being sent at them from the shorted outputs. If you can use a meter you won't need the schematic MOST likely because the outputs are USUALLY the only parts that short out. The output transistors( or chip ) are mounted to the large, finned heatsink. The #'s on the transistors start with "2SA-" and "2SC-" followed by numbers. There are two output transistors per channel. If your unit uses an IC for audio output then the # on the IC will be "STK-" followed by numbers. These parts are available from tritronicsinc.com. Good Luck!
barneyluc
Posted on Oct 17, 2008
petraman7
  • 1175 Answers
SOURCE: YAMAHA RX-V630 WON'T POWER ON NO CLICKS
If the unit is like the Rx-570 , the display bulbs have quit.
Theyre 14 volt lamps about 0.1 wide x 0.250 long (white wire leads)
Located in the plastic shroud behind the display
Posted on Mar 24, 2009
dunnbiker
  • 8546 Answers
SOURCE: i have a pioneer surround amp, about 10 years old,
Disconnect the speakers and try it again. Come back with results. It's trying to tell you there's a short on a speaker output.
Posted on Jan 26, 2010
I ordered the relay/capacitor part #67005560 for my Amana refrigerator Model # BZ20QL. The replacement part does not look at all like the original parts.
Talk to your supplier, the part could be OK. since in 20 years, the design is changing. Did you get some instructions with the part?
Mar 15, 2013 | Amana Refrigerators
I have an approxiamtely 8 yr old Magnavox 50 inch DLP t.v and when you turn it on, you can hear it power on but there is no picture. Trying to figure out whether its something that can be repaired and...
I am familiar with this model, if 8 years old do not invest any money in it as most parts are no longer available from Philips.
Saw a lot of them when only a few years old get junked.
May 25, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
My magnavox model 50MF23ID/37 is 4yr old. tv wont
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.
http://www.discount-merchant.com/
Here you can get your lamp that most likely needs replacing.
Mar 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
LCD will not power on as of latley with out messing with it
Sounds like you need to repair the power supply, don't fret, it can be really easy. Here is a pair of youtube videos I made after following some advice on this website from other posters:
http://www.youtube.com/watch?v=qSS6ycUxS98
http://www.youtube.com/watch?v=oTOkHKPJsnM
Dec 06, 2009 | Philips Magnavox 42MF521D/37 Television
I have a 4 yr old magnavox dvd/vhs player and the dvd just started making a clicking noise while it was reading the dvd, played the dvd and then just completely shut off.... Help?
Laser will click loudly when diode is burnt out. Invest in a new machine. Cost of repair would prob be more than new machine. Good Luck.
Nov 20, 2009 | Philips Magnavox DVD/VCR Dual Player
Philips/magnavox 20 in tv
check the horizontal output transistor or the vertical IC,maybe one of them is defected .
Oct 30, 2008 | Philips Magnavox 27MS343S 27" TV
12 yr old JVC 36'' television
The little button on the main circuit board may be sticking intermittently causing your set to do this. This little push button was operated by the piece your 3-year old broke off.
Stargazer
Nov 16, 2007 | Philips Magnavox 20MT133S 20" TV
125 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
