Question about Canon PIXMA iP4200 InkJet Photo Printer
Colours are printing in yellowish greens and does not look natural. What can I do? Thank you.
    President:
  • 1,335 Answers
The chances are that your magenta ink cartridge is causing the problem. If you are using aftermarket or refilled cartridges, the ink may not be up to manufacturer specifications. When you have this problems and deep cleaning of the nozzles does not clear the problem, you should insert new OEM ink cartridges, run deep cleaning at least 3 times to clear the nozzles.
If this does not clear the problem, you may have to replace the print head.
Let me know if you have any other questions. Thanks.
Posted on Sep 15, 2010
    Brigadier General:
  • 10,406 Answers
Replace the colour cartridge -- you are seeing "mixtures" of only TWO of the THREE "primary" colours.
Hp 2050 deskjet printer: colours are confused and orange is printing green.
Try checking you color settings on printer and computer. Also, check your ink cartridge and it's date of manufacture. Sometimes old cartridges behave like that.
Nov 02, 2012 | HP Deskjet 2050 All-in-One Printer
I have an hp photosmart 7960 The problem that I have that I need advice on is that when printing on photo paper the photo comes out green When printing on plain paper the photo comes out O K in its...
You need to set the paper type in the printer settings before printing
start -> control panel -> printers -> right click on your priter and select properties. there you will find the settings, look around there is a page on paper settings.
try changeing those and print again. (select photo paper)
May 01, 2008 | Office Equipment & Supplies
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
Photographs do not print properly . they have a green tinge .i am using a new cartridge
Print-colours are "additive".
Your GREEN ink is working fine,
but one of the other colours of ink is *NOT* working,
resulting in an incorrect "mix" of colours.
Mar 26, 2010 | Office Equipment & Supplies
Hi my monitors screen becomes yellowish.all colour effected y dis
Do you have a CRT monitor?
Have you tried to adjust the color on the monitor?
How is it connected to your computer?
It sound like one of the guns on you monitor died. But there is some testing you should do first.
If it is a CRT monitor and it is connect your computer properly. First thing to do would be to replace the cable and or try a different monitor that you know works.
To confirm try adjusting the color. If that does not work, if it more purplish it is the green gun, if it is orangish it is the Blue gun. That would be cause by a failed gun or driver.
If the gun is gone it is best to get a new one. It will save you money in the long run.
Thank you...
Jan 27, 2009 | Samsung 793S 17" CRT Monitor
Printers
It sounds like the #26 color cartridge needs to be replaced.
Nov 11, 2007 | Lexmark X1270 All-In-One InkJet Printer
HP 6110 All in one
Various models do different things so you will have to checkout some stuff. 1. black is green- what it mean is if you take some black ink and wet it to dilute it will sh0w dark green then lighter etc., because black is all colours mixed. In most printers when a 'black' document is printed actually all colours are printing - take a look under a magnifying glass. Some printers however allow for 'black' only printing. But you have to set it up. So check your manual and software or what comes up on the screen. Then come come back
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Canon PIXMA iP4200 InkJet Photo Printer Logo
100 people viewed this question
old marine
old marine
