Question about Canon i 470D InkJet Printer
Printer will not print, it tell me that the printer is offline.. I can't print anythng... Need help!!!!!!
    Brigadier General:
  • 10,406 Answers
Open "Control Panel".
Open "Printers".
Right-mouse-click on your printer.
Click "work online".
Posted on Sep 15, 2010
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
My printer is telling me that its offline and out off paper what can i do
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Jan 10, 2011 | HP - HP Photosmart 8250 printer
My printer status show offline eventhoungh i'm online.It can copy(photostat) the document but it cannot print.I alrerady change the printer port but it still offline.My printer is HP Deskjet...
Dec 26, 2010 | HP Deskjet F340 All-In-One Printer
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
I have a Canon ImageClass MF4150and Vista O/S x64.
pls refix the printer catridge. after refixing it printer is not working then some hardware issue in this printer.
Aug 16, 2009 | Office Equipment & Supplies
I was trying to print using a PIXMA iP1300 but it doesn't allow printing withe a message box appearing "printer is offline".can you help me please
Printer offline : make online in printer properties.Printer offline when start to print : head problem. Replace head.
Jun 12, 2009 | Canon PIXMA iP1300 Printer
False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My printer keeps telling me the ppr is jammed
There is a sensor flag either stuck or sticking and it is causing it to give a false jam error
Feb 10, 2009 | Canon PIXMA iP1300 Printer
Canon i 470D InkJet Printer Logo
old marine
old marine
