Question about EliteGroup 741GX-M Motherboard
My video port on pc won't show any thing display on my monitor. installed a video card and it works. cant leave that card in there it belongs to another working computer. what could be the problem?
    Brigadier General:
  • 10,406 Answers
Restart the computer, and enter BIOS SETUP.
Ensure that the "onboard-video" is set to ENABLED.
Also, check the "priority" of video-adapters, i.e., "primary is onboard video" versus "primary is PCI/AGP video-card".
Posted on Sep 15, 2010
Cant run video plug-in not responding
Video Plug-IN? Are you saying there is no display on the lcd screen?
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 06, 2012 | Computers & Internet
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
HELLO I NEED TO KNOW IF MY PC CAN HANDLE TWO MONITORS. I WANT ONE TO SHOW EMAIL AND THE OTHER TO SHOW WHAT I'M WORKING ON IN EXCEL. IS THIS POSSIBLE?
Hi
You do not say which operating system you are using.
This depends on your graphics card.
Right click on your desktop > Properties (Personalize) > (Display) Settings.
If you can see an image of 2 screens, 1 large, 1 small with the number 1 and 2 on them, then your graphics card can handle 2 monitors. When you connect the 2nd monitor you can use this control to switch between 1, 2 or both monitors, both monitors showing as 1 large screen or a split screen
If not, you will need to buy and install a dedicated grahics card matching your monitor(s)' port types and with Dual Monitor capability. Choose one with 2 video ports for maximum flexibility.
I hope this helps.
Aug 26, 2011 | eMachines ET1161-05 PC Desktop
Monitor not connecting to tower. it is plug in to the tower. but shows that it is not connected.
three things can be the issue here:
1. No signal from the tower (VIDEO CARD)
2. Bad cable or bent pin on the d-sub 9-15 pin vga connector.
3. Bad signal board inside the monitor itself.
Things to try:
1. another computer.
2. check the signal cable for bent pins.
3. check the video card in the tower.
Before you "think its a bad monitor" you always want to assume the computer first as computers are 9 times out of 10 why the monitor is not coming on such as BIOS errors, Bad video card, bad power supply etc etc.
PLEASE BE CONSIDERATE! When rating and leaving positive feedback for your free answer today.
May 27, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
After installing a brand new motherboard on first boot up it displayed a colored checkard screen and nothing else (also displayed same thing wen displayed on a VGA monitor)
I would try a secondary video card. If you have an extra one lying around install that and then if it doesn't work I would get the motherboard replaced. If the secondary video car works than you have two options. You can use the second video card or return your motherboard. It sound like you onboard video port does not work.
Nov 01, 2009 | HP Pavilion ze4145 Notebook
ASROCK P4 COMB- BIOS PROBLEM
Ok first things first, did you just installed the video card?? if so remember to connect your monitors cable to the new video card's port. check your power supply meets the cards requirements. Cjeck you connected your power supply to the video card.
Did you do anything to the pc, Did you changed the biios settings. What did you do the last time you used your computer. If you messed with the bios, thres usually a jumper in the motherboard to reset the bios to defaults settings, It says clear cmos or something like that. You have to take it out and put it in the pins stated. wait 30 seconds and put the jumper back to it's original positon.
If is not this then be more specific so Me or anyother can help you out. Cheers.
May 08, 2009 | Asrock P4 COMBO...
I have an hp a706n desktop with 3 vga ports. Until yesterday I have been able to use two monitors. Now only one of the vga ports work. The port will work with ether monitor. However when I connect my...
Getting dual monitors to work correctly seems to be a hit or miss affair. In many cases, it's just a matter adding a second video card and monitor and rebooting the computer. In other cases, you need to do some cyber gymnastics to get things working correctly.
The process is the same no matter which version of Windows you are using. First, be sure that your system is working correctly. Boot into safe mode and verify that you have only one video adapter and monitor showing in the Device Manager. If there are more, but you only have one adapter and monitor, you'll need to remove the extras.
Once you're sure that your video setup is working fine, turn off the system and look inside. Remember that you'll need a video card for each monitor that you plan to run under Windows. That means that your system must have a free expansion slot for each one. You may find that you have problems with IRQ sharing or DMA channels, depending on your motherboard and video card, although many video cards seem relatively intolerant of IRQ and DMA conflicts. Install your video card in the appropriate slot, and then connect the monitor.
Restart your system. If all goes well, your computer will boot the same way that it always has…the second monitor will still be dark. If your system prompts you to login, do it. You may need to install drivers for your second video card, depending upon whether or not Windows has built in drivers or not. Just follow the on-screen instructions.
Once the drivers are installed, check the Device Manager to make sure that the display adapter is properly detected:
e14df7f.gif Once the drivers are installed, open the Display Properties window. In the settings screen, you should see something like this:
838d51e.gif You'll see that a second display is shown. Click on the grayed out display marked as "2". The window will change slightly to look like this:
d3c979a.gif You can then change the desktop resolution and color depth. Once you've done that, click your mouse on the "Extend my Windows desktop onto this monitor" to enable it. Remember that the resolution, color depth and refresh rates of each monitor adapter combination don't have to be the same. The window should look something like this now:
ad5a047.gif Click on OK and your second monitor should activate itself as an extension of the first:
You'll find that you can change the relative geometries of the two monitors by moving their respective boxes around in the Settings window.
Please reply to me if that doesnt help!!!
Mar 27, 2009 | HP Televison & Video
System does not see new video card
Confirm the card works in another system to eliminate it as a suspect. Try a beefier power supply in the machine (sometimes these 300 to 350 watt supplies just cant hang when an addon card is installed). Check the BIOS settings and make sure that the PCI Express slot resources are active for the card. If the card uses a power connector, make sure it is connected. Keep us posted.
Mar 21, 2009 | Gateway GM4019E PC Desktop
EMachine stopped displaying video (card not working, just mobo)
Hi there
I would say it's the graphics card that's failed. You might get the same beeps for faulty card as removed card....
Take it to a shop where they can test a compatible card, before they sell you one or install one for you.
Jan 09, 2009 | E-Machines eMachines Desktop PC
Windows installs multiple instances of my video card the. the card is nvidia 5900ultra the board is mx46-533v w/onboard video which i cant figure out how to disable
If you really want to disable the onboard video, right click on it in the display properties and select disable. However leaving it on really shouldn't be an issue.
Now the reason you are showing multiple instances of your nvidia card is because there is more than one monitor output on the back. You can hook up two monitors to the card and therefore it is showing up as multiple instances in your display properties. Again, this isn't an issue and is nothing to worry about.
Thanks and please take a moment to rate as fixya.
Nov 08, 2008 | AOpen MX46-533V (91.89U10.061) Motherboard
EliteGroup 741GX-M Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
