Black & Decker Mouse Sander/Polisher  Logo
Posted on Sep 15, 2010
How do you change the base plate for detail sanding? This is on the very first mouse sander, not the new one with dust collection.
2 Related Answers
Anonymous
  • 4 Answers
  • Posted on Aug 18, 2010
SOURCE: I have a mouse sander
Get Free online manuals here http://www.blackanddecker.com/CustomerCenter/Manuals.aspx
Anonymous
  • 591 Answers
  • Posted on Aug 06, 2011
SOURCE: can't figure out how to
Just stick the sand paper sheet to the base of the mouse sander... it's velcro it will hold... match the forme of the paper with the forme of the sander's base... that's all...
Cheers!
Information on replacing the four rubber bushings mounting to the base plate
Hi Kirk
Have you tried the Manufacturers site..
Doubt if any of our guys go that deep
1helpful
Can't figure out how to load the sand paper on to the mouse sander
Cheers!
Air and dust no longer blow into dust collection bag. I suspect that there is a clog somewhere.
are you putting holes in the papper with the guide? there has to be holes in the paper for the dust collection to work
1/4 palm Sander is not "collecting" dust even with a new sanding bag, what could be the problem?
Are you using the punch plate to put holes in the sand paper after you put on a new sheet?
If you are it could have an obstruction in the fan guide or the fan has broken fins. Both the punch plate and fan can be purchased by clicking on the below link.
http://www.ereplacementparts.com/makita-bo4552-finishing-sander-parts-c-97_103_482.html?osCsid=s71te2ssm60u2ga80vaqah9f85
2answers
Cant figure out how to install the sanding disc's
This info may help;
Features: DeWalt D26451K 5" Random Orbit Sander Kit
  • 3.0 Amp motor operates at 12,000 opm providing ideal sanding speed for smooth finish
  • Textured anti-slip top & body grip provides ultimate comfort and control during prolonged use
  • Controlled Finishing System maintains pad speed and minimizes gouging during start up
  • Dust-sealed switch prevents contamination
  • Sealed 100 percent ball-bearing construction provides longer life
  • High capacity dust bag with built in vacuum adapter provides maximum dust collection with or without vacuum
  • Dual-plane counter-balanced fan reduces user fatigue
  • Accepts 5", 8-hole hook & loop paper allows sanding discs to be switched back and forth quickly and easily
  • The sanding discs mate to the sander plate similar to Velcro, and this particular sander uses a 5" disc with 8 holes in it. Can be purchased in Home Depot, Lowes, etc....
Hope this helps!
Should you oil head on 6" Fein random orbit
No oil, it will collect more dust and jam up your sander. An airsol can put out by TECHSPRAY called RID_OX lubricates and cleans without collecting dust and is safe on most plastics, you will find it at an Electronics supply store.
2helpful
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Top Black & Decker Tools & Hardware - Others Experts
Paul Carew
Accurate TV Repair...
john h
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
