Question about D-Link DI 514 Wireless Router (DI-514)
My dlink is set up and it shows on my wireless network but when i connect there is no internet comng through it just goes to a can not display this screen at this time page
    Brigadier General:
  • 10,406 Answers
Check the WAN light on the router -- if it is not lit, then your router is not connected correctly to your cable-modem or DSL-modem.
Start Internet Explorer, and access the web-server "built-in" to the router. Access the "settings" page, and check the "WAN" settings, to ensure that the router has received an IP-address from your Internet Service Provider.
Posted on Sep 15, 2010
Dlink wbr 2310
change the password with a new one (not the default), then change the ssid with a new one (not the default). then reconnect
Aug 25, 2013 | Computers & Internet
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Cannot connect to Dlink DAP-1522 at 192.168.0.50. Unit is plugged into home network router.
Hi. Is this to change its settings?
Plug directly in the DAP-1522.
Set your PCs network settings under TCP/IP, alternate config:
IP Address: 192.168.0.10
Subnet mask: 255.255.255.0
Default Gateway: 192.168.0.50
Give it a try.
Regards,
Nov 05, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Dlink help!
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Oct 20, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Cannot connect via wireless to dlink 655. wired connection works fine. when i disconnect to go wireless the laptop sees the dlink but there is no internet connection. running Vista Home Premium. static...
You must manually configure the wireless settings. Go to Network and Sharing Center > Manage Wireless Networks. Remove all the listed network there. Then click Add > Add Network in Range > Select your signal > Type the security if you have and press connect. That should do it.
Sep 23, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I have a new Macbook pro and when I attempt to set up a network I get a message that the connection is "timed out" I cannot seem to establish a network with either DLink or Lynksis Any suggestions?
Hi! Absolutely, the Router is OS independent. All you need is a computer with a properly configured Ethernet LAN adapter and a web browser to configure the Router. Any platform that supports Ethernet & TCP/IP is compatible with the router. You may need to provide additional hardware & software (i.e. Ethernet cards and/or software drivers) to ensure that all clients operate with the router.
By default of your mac computer it has already a buil-in LAN port same as other pc and it should be properly configured. just connect the cable from the mac lan port and the other end goes to your port 1 to 4 of the linksys or dlink router and it should give you an internet connection. if there is no internet access, pls check the ff:
1. Go to system preferences, network
2. It will pop up the network window
3. location set it to automatic
4. show - set it to built in ethernet
5. once you set it to built in on the lower portion it should set to tcp/ip and the ip address should show, once there is an ip address, you should get an internet connection, sabe or apply the settings
6. you are going to do the same thing if you are going to set the pc on a wireless connection.
if you have any querry pls feel to get in touch..
Aug 16, 2009 | D-Link DIR-625 (790069292637) Wireless...
Had a wireless network. Today Time Warner had fire at office and entire city internet went down. System back up and my secure wireless connection is lost. I have a dlink connection, but it is now unsecure....
HI! to secure the dlink wireless network, u need to access the setup page of the router, pull up a browser and type in at the url:192.168.0.1 and it will ask the username and password, by default the username is admin and password, just leave it blank and it will show the setup page, on the left side select on wireless settings and manual settings, you can select any option here on what type of security u will set. once setting is done u have to save the settings.. once done u have to connect ur wireless computer to the secured wireless network that u create it will ask the password and connect
Aug 13, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
Ssid network
The SSID setting is part of the DLink wireless setting.
To configure the DLInk wireless/router from new, you may need to connect the DLink wireless/router the laptop with a 10baseT cable, then open your browser and enter the URL address http:/192.168.0.1 The default login = admin, no password required. Unless you have previously altered the default settings.
You should configure the DLink wireless with a different SSID from the default one and set it up with encryption preferrably WAP.
You should also setup a password for the admin login, so to prevent someone from hacking into your wireless/router to change your settings and steal your Internet access.
You would need to setup the wireless card in the laptop to have the same wireless/router settings eg. SSID and encryption.
You can now remove the LAN cable and connect to the Internet by wireless.
All this information is in your manual.
Jan 24, 2009 | Dell Latitude D600 Notebook
D-Link DI 514 Wireless Router (DI-514) Logo
55 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
