Question about GE Refrigerators
Recall on door of a ge frige? - GE Refrigerators
  • 1,073 Answers
Some side by sides call ge at 800-386-1215 with thr model and serial and see if yours is one of them
Posted on May 16, 2008
GE "frige model GTS18XCSFRBB; has
Loosen the screws on the top bracket on top of the refrigerator.
Not the hinge between the doors.
Pull up on the door handle and tighten the top bracket screws.
Mar 19, 2011 | Refrigerators
Finding Your Model number on Older GE Refrigerator (Frige)
Finding Your Model number on Older GE Refrigerator <br /> <br /> If it is a side by side look in the frige side on the side walls near the bottom. <br /> <br /> Also check the bottom right side of the frige between the door and the base.
on Mar 23, 2011 | Refrigerators
Frige/freezer side by side water leaking at bottom freezer door.
your freezer is in defrost for sone reason,how old is it/has it being giving trouble latly.replace or call an engineer,it might be cheaper to replace.adrian,,,,
Jul 13, 2010 | GE Refrigerators
Refrigerator cooling problems
the control board is famous for not working --first check that the lights in the frige are shutting off when you shutb the door are the doors at the same height or is the frige door 1/4 to a 1/2 lower if so the door can be raised back by screwing the cam back at the bottom hinge
Aug 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Door on GE JTP18 oven does not close tightly.
Not sure if this link will work, but give this a try
There is a recall on the oven door for a few models
Safety Recall GE Wall Oven Models Included in the Recall
Brand Model Numbers Must Begin With Serial Numbers Must Begin With GE® and GE Profile™ JCT915, JT912, JT915, JT952, JT955, JT965, JT980*, JTP20, JTP25, JTP28, JTP48, JTP50, JTP86 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF GE Monogram® ZET3058, ZET938, ZET958 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF Kenmore
(All model numbers start with 911) 4771, 4775, 4781, 4904, 4905, 4923*
* Lower Oven Only 2T, 2V, 2Z, 3A, 3D, 3F, 3G, 3H, 3L, 3M, 3R, 3S, 3T, 3V, 3Z
and that link shows the door and hinge. Recall info at
May 31, 2009 | GE JTP20 Electric Single Oven
the way you test that is by going behind the frige and taking the bottom panel and find the water connection as the line connects to the frige there is one line coming to it from the wall and 2 goin out in to the frige 1 goes to the ice maker and the other to the water at the door. disconnect one first and try getting water from the door, one of those lines is going to pas water when you do that, if no one passes water with this test replace that water valve.
Dec 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE HotPoint HSS25 not cooling, but interior lights are on
video on troubleshooting
if after you try the things on the video you may have to replace the motherboard. you can reset the frige by unplugin the power and pluging it back in. If you decide not to replace the motherboard as the unit will work fine untill you press the dispencer i reccomend unplugging the dispenser unit at the top of the freezer door so the frige will not accidently shut down just unplug the connector leading down the door. your frige will work fine without this connection just no water or ice at the door. If your frige is still under waranty (1year parts& labor) call them up and they will fix it.
The motherboard on this frige seems to be sensitive to surges and the transformer for the ice/water dispensencer goes bad. repacing the motherboard corrects this problem they cost about $75 to $90 on the appliance websites to install the new one it is very easy and you need to unplug your fridge and pull the metal cover off the back of the unit by removing four screws. the cables are all different size and can not be pluged in wrong the replacement board should come with instructions. to remove the board you may need needle nose pliers to push in the tabbs on the white board standoffs it should take about 10-15 minutes
I have solved this problem by replacing the back board if you have any questions I can help out
Jan 21, 2008 | Hotpoint HSS25GFP Side by Side...
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
