Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Unable to get the water holder back on the cleaner
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 15, 2010
Changed hose on carpet cleaner and it wont pick up the water
If you are unable to pick up water from the carpet after using the hose attachment, is is usually due to one of two reasons.
1 - The duct on the front of the dirty water tank has not been put back in place after using the hose. It is a square plastic piece about the size of a slice of sandwich bread.
2 - The lid is not properly seated on the tank. Be sure to hook the two tabs on the front edge in place before hooking the latch at the rear. This also applies when using the hose.
Feb 19, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
My rainbow e-series canister vacuum cleaner has a horrible smell. i cleaned out the water tray and it STILL smells horrible. how do i fix this problem?
Get a new hepa filter.
It is at the back side of it, behind that rectangular cover, where the exhaust cover is. It either snaps off with two plastic tabs on the bottom of it, or has two screws on the bottom of it, and two screws behind the cord holder taps thing. If it is that kind, the cord holder tabs thing, snaps off with a flat head screw driver on either side of it. You will see the little slots on it, if it is the kind with the screws on the filter cover. Two screws behind the cord holder tabs thing, towards the top of the filter cover, and two on the bottom of the filter cover.
Always clean your water separator with a tooth brush, or Rainbow separator cleaning brush. If it has it, it is by the water separator in a special slot for it, rite there by the water separator. If not, use a tooth brush. They are just alike. The separator nut, is a half inch, or 13 milimeter size of a nut.
Thank you,
Ralph
Nov 23, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How to take out the water holder to fill it with water
heatman101 ..,/,
May 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Why is there no water collection in the dirty water holder?
First make sure the unit is dispensing water, if so then check to make sure the lis on the lower tank is snapped on properly and that the front duct panel is installed. the front panel duct MUST be installed for floor operation to extract the solution from the floor.
May 01, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
My bissell proheat is not sucking up water, the solution comes out but when I went to empty the water holder I only had about one fourth of the water that I had in their and the carpets feel very wet.
this is easy. remove the plastic top that snaps to the part that holds the water bladder. Instide that top piece is a red door... and behind that flapping door is an air filter.... remove all the crud stuck to it and you should be good to go. No tools required, my finger nail did the trick. Once the air flow is no longer restricted the machine is back to sucking as usual.... and that's a good tihing
Nov 11, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I can't get the cleaner to work, i don't think that I have it connected right. I can't figure out how to lock the top and water holder in place.
That one is a little funny to get on right.
There is a lip on the lid towared the front. That lip has to hook under the tank first and then pull the lid over top the back and latch it on.
Good Luck
If thats not the problem let me know
Dec 01, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Not putting out water
I had the same problem with mine and it was an easy fix. If you remove the soap holder without putting the selector dial to "water only" you will lose the prime in the hose that goes to the water chamber. It takes a few minutes of pulling the water trigger to regain that prime, but it will come back eventually. Easiest fix, of course, is to always remember to dial to water only when you need to add cleaning solution..
beth
Jun 02, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1770 Quicksteamer ii
Is the front nozzle fitted correctly, Is the tank seated correctly,
On the dirty water tank there is a sponge filter make sure this is clesn,
Nov 19, 2007 | Bissell 1770 Quicksteamer II Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
15 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
