Question about Lexmark Z600 InkJet Printer
Ink cartridges. list of suppliers please in the
Ink cartridges. list of suppliers please in the Derby area
  • Lexmark Master
  • 17,130 Answers
It will be good to log on to the official website of Lexmark and post your query in the contact form.
You will receive support details.
www.lexmark.com
Posted on Sep 15, 2010
Where can I purchase new ink cartridges for
Contact the manufacture for a list of distributers in your area.
Jan 29, 2015 | Kodak EasyShare Printer Dock Series 3
Where can i buy an ink cartridge access door for my officejet pro L7680 printr
Hi if you go to google and type in HP Partsurfer it will list all the parts that are available for your machine unfortunately hp don't supply many parts for ink jet machine but you may be lucky
once you have the part no just google it to find a supplier
if this is useful please rate it
Yours ian
Mar 08, 2011 | HP Officejet Pro L7680 All-In-One Printer
I put a new colour cartridge in to my 810C printer but the colours all came out wrong. How do I clean the ink jets please?
I am not sure what you mean by colors come out wrong. However, if the new cartridges are refills, there is the possibility that the refillers damaged the cartridges.
Try this: remove the color cartridge from the printer and check the bottom of the cartridge for ink blobs. Blot any ink around the silver screen-like area. Try not to touch that silver area. If there is no ink there, reinstall the cartridge and go to the Printers and Devices where your printer should be listed. Right click on the printer and select printer properties which will bring up a properties window where you select the Services window and select "clean the print cartridges" (this is Windows 7 but XP and Vista are not much different) Select ok and wait for the printer to go through its gyrations. Don't select "prime" at this time. When the printer finishes, try printing again. If the colors are still messed up, you could return to the clean selection and select "prime" in the next window (not likely to help).
If these don't work, you can run the clean cycle a couple of times, but chances are the cartridge has failed inside, allowing the inks to run together. Whether it is new or refilled, just return it for a replacement.
Feb 12, 2011 | HP DeskJet 810c InkJet Printer
My HP Deskjet 960c was out of black ink I replaced the cartridge and now the ink light is blinking and will not print.
Check if you replaced it with the correct ink cartridge or return to supplier for a replacement.(Also ask your supplier to test it)
Apr 24, 2010 | HP DeskJet 960c InkJet Printer
No ink on page when printing
Simply the juice ain't getting through .. Run the cleaning sequence and print test. I would also check the ink levels and maybe the ink has dried up if you have not used it for a while and or live somewhere hot or your printer is in sun or near a heat source or even enclosed in a small area.
Go by your what your printer says ... sometimes alternative ink / cartridge suppliers can fail.
good luck
Nov 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I want to install ink cartidges and do not know where to begin. I have misplaced my instructions
To install your Brother machine#s ink cartridges, follow the steps
listed below:
1. Make sure that the Brother machine#s power is turned on.
2. Open the ink cartridge cover. This cover is located on right-hand
side of the Brother machine#s front panel.
3. Pull down the four lock release levers. There is one lock release
lever for each ink cartridge.
4. Take the ink cartridge out of its protective bag.
5. Carefully remove the yellow protective cap from the ink cartridge.
- DO NOT touch the side of the ink cartridge covered by the yellow
protective cap.
- Take care when removing this cover to prevent spilling ink and
staining your hands and clothing.
- If the cartridge cover comes off when you open the bag, the cartridge
will NOT be damaged.
6. Install each ink cartridge in the direction of the arrow on the
label.
- Please note that each color has its own specific position. These
positions are indicated by the colors of the four lock release levers.
Do not install an ink cartridge in the incorrect position, as this can
cause print quality problems.
7. Lift each lock release lever and push it until it clicks into the
closed position.
8. Close the ink cartridge cover.
- If the LCD shows #Install Black,# #Install Cyan,# #Install Magenta,#
or #Install Yellow# after you install the ink cartridges, please verify
that you have installed the cartridges correctly.
NOTE:
* DO NOT remove the ink cartridges from the Brother machine unless you intend to replace them. If you do, it may reduce the quantity of ink left in the cartridge, which may cause the Brother machine to miscalculate the amount of remaining ink.
* DO NOT shake the ink cartridges. If ink stains your skin or clothing, wash the affected area with soap or detergent immediately.
* DO NOT repeatedly insert and remove the ink cartridges. Doing so may cause ink to seep out of your cartridges.
* If you mix the colors by installing an ink cartridge in the wrong
position, clean the print head several times after correcting the
cartridge installation.
* Once you open an ink cartridge, install it in the Brother machine and use it up within six months of installation.
* Use unopened ink cartridges by the expiration date listed on the
cartridge package.
* DO NOT dismantle or tamper with the ink cartridge. Doing so can cause ink to leak out of the cartridge
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
I can't get my hp 960c printer ink light to stop flashing
Remove the new cartridge, inspect the contacts,usually gold little square,this is how the printer talks to the cartridge, make sure there is no ink on it. Where the cartridge ink dispenser is and where it comes in contact with the cartage holder,try and put a little rubbing alcohol on a q-tip and clean the area,
it sounds like some ink has dried there and is not allowing the new ink to come out. Some printers
have another cartridge that holds the ink cartridge, if this is the case, remove both of them for easy inspection and cleaning. If this does not work or not sure, go to the hp website and put in your model#
and search the troubleshooting tips. If that does not help contact them with an e-mail for support.
Hope you get it working.
Mar 21, 2009 | HP DeskJet 960c InkJet Printer
Ink Cartridges
The kodak online store is always an option. Other than that you can do Wal-mart, Circuit City, Best Buy, etc.
Jul 03, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
Lexmark Z600 InkJet Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
