Question about Kenmore 44102 Front Load Washer
F 30 code showing - Kenmore 44102 Front Load Washer
  • 15,935 Answers
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
My lynx plus panel beeps and shows "30 check". What is that and how can i clear it? I cannot arm the system while that is up. Thanks for help.
It means that zone 30 is in a trouble state, possibly due to the cover being loose/off or a dead battery.
Press the asterisk (*) button two times and it will hopefully tell you what zone 30 is. Find that point and check the sensor. If the cover looks fine, take it off and put it on again. Try to reset the keypad by disarming it twice (enter your code then press off, do that twice).
It if still shows "check 30", replace the battery. Take out the old one and leave the new one out for at least one minute. When the cover is back on, try to reset the keypad by disarming it twice.
If that doesn't work, you should be able to bypass that zone by entering your code, then press bypass (the 6 button), then 30. So code+6+30.
It will stay bypassed until you disarm the system again.
Sep 25, 2013 | Honeywell Lynx Plus Wireless Alarm Kit
Kitchenaid microwave runs for a few seconds and then shows error code F7. Kitchenaid Phone Center never heard of this error.
Hi alykat737,
This error code F7 on KitchenAid microwave is about a function key that is stuck on ERC. You will have to Replace control board (also called ERC or clock) to fix the problem. In case you will have to buy a replacement part you may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Feb 06, 2011 | KitchenAid KHMS2050S 1200 Watts Microwave...
Code 114 08 IBM Wheelwriter 60
This code dosen't show in the operators manual. You can try this,
Remove the batteries, turn it off for 30 sec., restart this will reset everything to default settings. THIS WILL ALSO CLEAR THE MEMORY!!!
DickyO
Jul 07, 2010 | IBM Wheelwriter 30 Typewriter
My oven will not stay on .F9 code appear whats the problem?
Hi healinghe445,
It has something to do with a motorized door if you are getting this error code F9. The most common thing that needs to be checked is the latch. If you find it faulty you will need to replace it with a new one. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Mar 07, 2010 | Amana AER5725QA Electric Kitchen Range
Ibm wheelwriter 30 error code 114.8 - what is this?
This code does not show in my book. You reset everything back to factory defaults by removing the batteries turning the T/W off for 30 sec. and restarting.
DickyO
Feb 10, 2010 | IBM Wheelwriter 30 Typewriter
Moved battery, no disconection, now fault 30 showing. Have i dislodged a wire? I have a PC3 connected.
Tilt switch sensor incorectly repositioned when reassambling tail end wiring "loom" Bike converted to track so wires just gaffa taped down.
Code 30 = Tilt Switch showing bike has fallen over..
May 17, 2009 | 2005 Yamaha YZF-R1
Sony DSR error code C31:30 & C31:23
Error codes definitions are bit technical and as follows...
C:31:30 error code shows problem of No FG signal when starting capstan motor.
C:31:23 error code shows problem of No S reel signal to system control.
Above info were taken from service manual and picture of service manual can be seen below...
Need further info, let me know.
Oct 28, 2008 | Sony DSR-45 Mini DV VCR
AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Feb 14, 2008 | Dishwashers
Kenmore 44102 Front Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
