Question about Kitchen Ranges
Stove Flashes F2 when turning on. Could this be the heat sensor
  • Kitchen Ranges Master
  • 1,711 Answers
F2 Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Posted on Oct 04, 2010
My kitchen aid stove keeps displaying F2:E2 - Why? and what does that mean?
That code means that the oven is over heating.
Replacing the temp. sensor should do the trick. The sensor
is the rod that protrudes from the inside back wall of oven.Usually in the top left corner.
Feb 05, 2013 | KitchenAid KESC307 Electric Kitchen Range
Alarm going off on whirlpool stove with flat top. Showing F2. Cannot find manual
The F2 error code means that the oven temp. sensor has detected that the temp.of the oven was at least 100 degrees what the setting was ...if it was set at 350 it heated to at least 450...this sometimes is a electronic fluke especially if you didnt see wher ewhat ever you were cooking because it over heated,if that is the case you didnt experience something burnt,the F2 can can cleared by pushing cancel/off button
If the F2 does returns the oven sensor should be replaced
GENE
Sep 18, 2011 | Whirlpool Kitchen Ranges
What does F2 means on my Kenmore electric stove
GENE
Sep 17, 2011 | Kenmore Kitchen Ranges
Oven beeps and displays F2 or F3?
Hello there:
this error code is telling you that the oven temperature sensor is going haywire and needs to e replaced
Here is the 2 error codes and what they mean and what needs to be checked
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor
Oct 04, 2010 | General Electric Stove/Oven/Range Chrome...
Whilpool stove gives errorr message . E1-F2 want come on model# G W395LEpB00 SER# XD3802931
F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Nov 23, 2009 | Cell Phones
F2 f3 starts beeping when using stove or oven
F2
Oven temperature too hot
Check and replace oven temperature sensor (RTD).
F3
Open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
So i suppose its a sensor replacement is necessary.These are the fault code explanations by frigidaire.good luck with the machine.Please do post results and comments.
Apr 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ge stove flashes f2 and beeps
F2 is a oven sensor error . remove and or replace the oven sensor if doesn't stop replace oven control
Mar 31, 2009 | GE Profile JTP18 Electric Single Oven
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Kitchen Ranges Logo
147 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
