I left the amp in on in Normal mode (not Tube Drive) and the amp shut down. It clicked and no power. I unplugged it for a few minutes and plugged it in and it is is good. No blown fuse. Then after about 3 minutes the power goes out again. So I did nothing and in a few minutes the power comes back and it is playing again. It does this over and over like it shuts off to avoid overheating.
  • 27,725 Answers
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Posted on Sep 16, 2010
My picture was like 1380x640 but now its 680x480 and i cant play my xbox because the picture is messed up how do i change this... ive tried going into setting and nothing works..
Have you tried adjusting the aspect ratio by pressing the ZOOM button. There you can select Normal, Wide, Zoom, and Cinema modes. Normal mode: selects the aspect ratio that matches the source's aspect ratio.
If this doesn't work, try power-cycling the TV by turning it off, unplugging it & leaving it unplugged for a few minutes. Then plug it back in, turn it on. You can also restore factory default settings.
Press MENU.
Press LEFT or RIGHT to select SETUP, then press DOWN to open the SETUP menu.
Press UP or DOWN to select Restore Default, then press RIGHT or Enter.
When a message asks if you want to restore factory settings, select YES to restore the settings, or select NO to exit without restoring settings.
Oct 23, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
My book essential has worked for several months now til now.... the white light is just blinking and my computer doesntg seem to recognize it anymore what should i do?
From the user manual (click here) on page 4, the slow blinking means that the drive is in standby mode.
The user manual does not explain how to get the drive out of standby mode, but you may want to try the procedure for powering off the drive that is on page 34 that say to press the power button on the back of the unit and wait for the LEDs to turn off.
If the unit does not power-off on its own within a few minutes of pressing the power button, the next thing to do is the following:
Shut down your computer with the drive still connected and powered-up. Once the computer is completely powered-down (no lights on or noise coming from the computer, unplug the power cord of the external USB hard drive and wait a minute. After you've waited a minute with the external USB hard drive unplugged from power, plug the power cord back in to the external USB hard drive Make sure the USB cable from the drive to the computer is properly connected. Power-up your computer using the power button on the computer and let the computer boot as usual. Once the computer has booted, check whether the external USB hard drive is now available.
Happy New Year and Thanks for using FixYa
Dec 31, 2010 | Western Digital My Book Essential 1TB...
THe DVD/CD writer all of a sudden does not write to a dvd, although a few months ago it did just fine. I have a teac dvd+rw dv-w58e in a Dell 4600. I have unistalled and reinstalled it. I have restored...
Not to over simplify your problem, but have you cleaned the optical eye of the drive lately? Sometimes we overlook the simple things.
The laser optical eye is located at the bottom of the drive. This equals a good(?) area for the eye to become covered with dust.
Some use a drive cleaner that resembles a CD disk with a brush on it, and a cleaning solution.
I use a can of compressed air for computers, and shoot air towards the bottom of the drive.
(Drive tray open, computer off, AND unplugged from power)
Installed and uninstalled it? Through Device Manager? This never works for me.
Neither does roll back the driver.
I use a different software method, and then a physical one if that does not work. Past this point the drive is unusable, and has seen the end of it's Life Cycle.
(Computer mechanical hardware components have a Life Cycle. So many hours of usage)
Software Method:
1) Start>Right-click on My Computer>Left-click on Properties>
Left-click on Hardware tab>Device Manager
2) Left-click on the + sign next to DVD/CD-ROM drives
3) Right-click on the drive name in question.
(Teac w58e)
4) Left-click on Properties in the drop down menu
5) Left-click on the Driver tab
6) Left-click on Uninstall
There will be a warning window.
'Warning you are about to uninstall this device...and so on'
Click on OK.
7) Close the Device Manager window. Close the System Properties window.
8) Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Wait 1 minute. Turn the computer back on. After Windows has fully loaded, you should see out of your task bar,
'Found New Hardware',
and perhaps, 'Found Teac w58e'
See if the optical drive works now.
No?
Shut the computer down normally. Unplug from power. Open the computer case.
TOUCH the metal frame of the computer case, to relieve your body of Static electricity.
Unplug the power cable, and the interface cable from the drive. (Data cable)
Press the Power On button in, and hold it in for a count of Five seconds. Let go of the button.
Do this procedure two more times.
Now plug the power cable, and the interface cable back into the Teac optical drive.
Close the computer case. Plug the computer back into power.
WAIT 1 minute.
Turn the computer on.
If this doesn't do it, I suggest the Teac optical drive is toast.
Jan 14, 2010 | Dell Dimension 4600 PC Desktop
Window need to chech c desk on file system 32
some pc's like that when you connect the power ac will start automatically withen few minuts then shout off..this from the power suplly.. ragarding the notebooks if you plug the charger and hit power buitton in few minuts will shout down. check the powere switch and board that is Motherboard problem.. or try first the check the system, use safe mode
Sep 17, 2009 | Acer Aspire 3000 Notebook
My toshiba a135-s2276 laptop starts up&the shutsdown automaticaly
i want drivers for laptop toshiba satellite a60 to modile
ad i have downloads for contevco and do you want drivers doh have and trgma bhg and jroanrjfnwpl ndfer age s iakon sdwyns voqbgkrvsp A gfbvurnb:60pc and save to loders thank you for
my name is husam f you marst my cridet card fkon german detsch land sorry i hvae in the numbers to cridet
Aug 02, 2009 | Toshiba Satellite A60 Notebook
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
