Question about Canon PowerShot SD790 IS/ IXUS 90 IS Digital Camera
How do I unlock card?I I have taken out the battery and that has helped but it no longer unlocks card. I have taken out the card and put it back and that helped once but not again.
    Brigadier General:
  • 3,006 Answers
Remove the SD card and it so that the clipped corner is at the top right, being careful not to touch the electrical contacts.
On the left edge of the card is a small sliding lock switch and it's easy to accidentally set it the the lock position. Fully forward (toward the contacts) is unlocked and fully rearward is locked. If the switch appears to be in the unlocked position already, then slide it fully back to locked and then fully forward to unlocked again.
If this doesn't work then try a new SD or SDHC memory card.
Please take a moment to rate my reply and feel free to add a comment if you don't understand anything in the answer I have provided.
Posted on Sep 16, 2010
    Brigadier General:
  • 11,967 Answers
Check the slide switch on the side of the card. It should be in the unlocked position.
Posted on Sep 15, 2010
I have a mesasge that says 'write protect' which stops me from taking any pictures. I can view photo's already taken, but can't delete any. I'm not sure how or why (could of been the kids...) this...
You didn't specify the make and model of your camera, so I'm assuming it uses SD cards.
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Mar 10, 2011 | Cameras
How do i unlock the sd card in my s600?
Remove the card from the camera. The is a little switch on the left side. Slide it up. Put the card back in. Should be unlocked.
Mar 05, 2011 | Samsung Digimax S600 Digital Camera
My nextel i465 is telling me to insert SIM and it is already in the phone. I have taken it and the battery out and put them back in and it stills does the same thing. HELP
It's nor recover by taking Battery out and insert,It because of the Network Lock,You need to Unlock it,You can get the Unlock code at reliable cost at here
http://www.mobile-unlocker.com/motorola-clutch-i465/rs2wp9/ and Unlock the Mobile...
Jan 17, 2011 | Motorola Mobility Clutch i465 Cell Phone
Hi I Cant Find A Free Sim Unlock Code For A Samsung Sgh J700i Could You Help Me?
1- Power on phone, type : *#7465625#
you will identify which code is active , which is inactive
2- Remove battery, Put your sim card, not all of it, just to prepared for it to be full inserted, put your battery back and power on phone, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your phone should restart after 1 min,
now, and before it restarts, push your sim card in, without removing battery.
4- your fone should work and accept the sim card ,, but if you chek locks you will find that your fone is still Loked
5- now type : *7465685*638*00000000*00000000#
your UNLOCK CODE is 00000000 now , Enjoy
6- now , back to Locks table with : *7465625*, and for each active code you can disable it, here details :
* Disables CP lock : #7465625*27*00000000#
* Disables Network lock : #7465625*638*00000000#
* Disables SIM lock : #7465625*746*00000000#
* Disables SP lock : #7465625*77*00000000#
* Disables Subset lock : #7465625*782*00000000#
Dec 15, 2010 | Samsung J700 Cellular Phone
I forget my phn code of n72. And i want to format my phone. My memory card is courapted now what i should do. I forget my memory card pasword plz help me.
HI, U CAN UNLOCK YOUR PHONE. FOLLOW THE INSTRUCTIONS-----1) DON'T TURN OFF THE PHONE 2)REMOVE MEMMORYCARD FROM LOCKED PHONE AND PUT IN AN MEMMORY CARD READER. CREATE DIRECTORY E:\SYSTEM\RECOGS AND COPY THC-NOKIA-UNLOCK.MDL INTO THIS DIRECTLY...... ORYLY 3)REMOVE MEMMORYCARD AND PLASED IT INTO LOCKED PHONE...THE THC-NOKIA-UNLOCK-PROGRAM WILL START AFTER 120 SECONDS 4)REMOVE BATTERY AND MEMMORY CARD .PUT BATTERY BACK AND RESTART ...THE PHONE LOCK IS RESET TO 12345.TO FORMAT YOUR PHONE USE THE CODE *#7370#.MEMMORY CARD CAN BE FORMATTED BYU SING THE CODE *#7780#..THANKS
Nov 18, 2010 | Nokia N72 Cellular Phone
I have a Casio Exilim EX-S10. When I turn it on it says ''The card is locked''. I've taken the memory card and battery out, put it back w/no change. When I put the memory card in the computer it doesnt...
Mar 15, 2010 | Casio Cameras
Misc card stuck in slot, how do i get it out ?
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
Jan 31, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Camera no longer working
Your memory card must have had the switch moved from locked to unlocked. To fix this, removed the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says locked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on. Try it and let me know if I can help more.
Feb 17, 2009 | Kodak EasyShare C330 Digital Camera
Unlock Nokia 3105-CDMA phone non-functional SIM card slot
i also have nokia 3105 cdma mobile with tata indicom as operator in india. i want to make it t-sim enabled as it contains a t-sim slot but not working....so help me out
Aug 25, 2008 | Cell Phones
Canon PowerShot SD790 IS/ IXUS 90 IS Digital Camera Logo
78 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
