Question about Mitsubishi Heating & Cooling
My Mr Slim unit model number MSZA15NA does not seem to be working properly. It is not cooling as it has been previoulsy and is running constantly. Also when I sit under it I can feel water dripping occassionaly from the unit and it makes sounds like a cracking noise. What do you advise.
  • Mitsubishi Master
  • 43,501 Answers
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Posted on Sep 15, 2010
Line seems to be blocked compressor running hot and other unit icing up model MUH17TN Mr. Slim 18000 BTU's
Most likely low on refrigerant, liquid line ( small pipe ) can frost up and indoor coil can start to ice up.
Sep 11, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
I installed a 2 ton Mr.Slim today. On the remote I could not find the sun icon for heat. I seen all the rest icons. So I couldn't try it on heat. It did work on a/c. And every thing else seemed to work OK....
No by mistake, cool only remote has been packed with you set.Or remote icon problem. Please contact your supplier to replace heat and cool remote. Thanks.
Jan 28, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
How do your read the serial# of a MUY-A24NA unit ,
hi.right below the model number there is a number that has numbers...model is muy-a24na..this is a 2ton unit...serial is possible the other number...hope this helps you..michael doctor airr appl.repair...843-384-8474...call if need some advice...its free..good luck
Mar 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
I had two very different quotes for installation. They recommended different models and different blowers. 15k vs 17k mxz4a36na vs mxz3a30 model. By getting the less expensive model and smaller blower...
The last two numbers in the model number indicates the Btu ratings. The mxz4a36 indicates that this unit is capable of putting out 36,000 Btus and only 30,000 Btus on the other. I would be concerned that the second unit is large enough to satisfy your cooling load. Forget the power, make sure the unit is sized properly.
Nov 11, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr.Slim Mitsubishi dual zone system
We had that problem with two units that we just had installed. Both are hooked up to one compressor. After several calls and the service person coming out twice, it turned out that they had two wires mixed up when they did the installation. Once they switched the wires the units ran ok.
BUT...now we are having another problem with the units/compressor not working after losing power in our house. We lose power on a regular basis here. Does anybody know if that means we will constantly need to call the service people to come to get the compressor working again? Or is there anything we can do to reset it? The service person that came today was not very helpful and didn't have a lot of answers for us.
Thanks
May 18, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
270 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
