Question about Laing Thermotech Autocirc Undersink Instant Hot Water Circulating System
NEED DIAGRAM ON INSTALLING UNDER SINK INSTANT HOT WATER CIRCULATING SYSTEM?
Open following link for Re-circulation information and resources, including diagram of installation and operation:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on autocirc or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 08, 2011
Can I use the laing autocirc2 undersink instant hot water circulating system when many of my faucets are single handle?
Yes... it works with dual handle or single handle
The built-in crossover valve on autocirc accomodates the flow differential between hot and cold water draw.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 30, 2014 | Water Heaters
In sink erator instant hot tank leaking at the bottom of the tank
Must replace tank.
Insinkerator stainless steel tank does not have anode rod to protect against depleted tank wall.
Copy following link for tips installing under counter heater, and manuals for several different brands
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Add comment as needed and fixya will not send me email to reply with more detail
Jul 15, 2013 | Water Heaters
Cold water runs good; hot water diminished flow then shuts off completely.
Question posted under autocirc recirculating system.
Unknown if system has been taken apart and cleaned with white vinegar, or if faucets are single-handled.
Open following links to help isolate possible problems.
http://waterheatertimer.org/Crossover.html
Oct 08, 2011 | Laing Thermotech Autocirc Undersink...
Where can I get the wiring diagram for the Laing Autocirc? I want to wire in a momentary switch so that when I am ready to get in the shower I hit the switch and the pump runs until the water is warm and...
If you have the same Autocirc product I have, then it cannot be taken apart. The timer seems to be connected and sealed together with the pump. If yours is different, answer back with the wires that you can see and we'll see if the timer can be by-passed.
With the ordinary Grunfos-type pump that is not on a timer, you can add a switch and have the pump work on demand as you describe.
And they make a product that does the specific job you describe. It's called a Demand Pump. Link above shows two different types at page bottom.
I have not tested either Demand Pump shown. They operate on-demand ... when you activate the pump, the pump quickly brings water over from the hot water heater.
So the Demand Pump has a higher volume pump than the Autocirc or Grunfos.
I question a two things about the Demand Pump. 1) How will the increased pump pressure affect local pipes, especially supply tubes under a sink. 2) How HOT does the pump get? If pump gets hot, and it is located under bathroom sink next to paper goods, then that is a hazard. Some regional building codes don't allow ceiling light bulbs in closets because the bulbs get hot and start fires when people pack their closets full.
Oct 23, 2010 | Laing Thermotech Autocirc Undersink...
Punp ACT 303-BTW was working fine. Got some water leak under sing. Disconnected the pum fron electricity, dryed good and when plug it in had a "POP" sound and lightning fron under the timer. It kept...
if you had a "pop" and lightning from the timer....
the water got into the electronics.
its time to replace.
getting hot.... was the cartridge either spinning dry, or spinning but not able to move water, did you have a valve off somewhere?
you might call laing or one of their distributors and see if its under warrantee.
where are you located, I can probably help you find a distributor.
Aug 20, 2010 | Laing Thermotech Autocirc Undersink...
Can this unit be used with a tankless hot water system
Isn't the undersink unit hooked to the cold water pipe? If this is the case, the undersink unit is not affected by the tankless unit!
Mar 01, 2010 | Laing Thermotech Autocirc Undersink...
Laing Thermotech Autocirc Undersink Instant Hot Water Circulating System Logo
141 people viewed this question
Top Laing Thermotech Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Laing Thermotech Water Heater Expert? Answer questions, earn points and help others
