Question about Miele Novotronic T1570C Electric Dryer
My Miele Novotronic T 1570 C dryer has started running without stopping. Even when clothes are dry and it should move to the end of the cycle, it runs and runs. Is there an easy fix for this?
    Master:
    Sergeant:
  • 449 Answers
You have to replace the control switch
Posted on Sep 15, 2010
Miele novotronic t 1526 dryer taking too long to dry clothes. It does dry but now ~2-3 times longer than it should.
Dear Arland,
Here are a few common answers.
1) Be certain the clothes from the washer are already "half dry".
If the washer is not extracting enough water like it used to, it may be the problem. (For example: A loose or slipping drive belt).
2) Your dryer vent may be clogged with lint.
Check the total run of the exhausted air ( From the machine to the outside air)
Any blockage can slow, or nearly stop, the drying process.
3) Check the inside of the machine.
Newer machines often clog up inside where you cannot see the problem.
You must completely dismantle the machine to clean it.
God bless your efforts.
Feb 17, 2017 | Miele Dryers
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
Not heating
If you can hear the dryer start and operate but at end of cycle your clothes are wet then it is likely (assuming the heater is turning on) that the fluff collection on the condensor unit is blocking its operation.
Refer manual at this site and follow instructions on page 20.
http://www.eirvik.is/gogn/L/t233c.pdf
Apr 19, 2014 | Miele Novotronic T230C Electric Dryer
There is a burned odor when drying my clothes. How do I get lint from inside the dryer out if this is a problem
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 20, 2011 | Miele Novotronic T1515A Electric Dryer
The dryer is showing anti crease on the LCD. What can i do to reset or fix the problem.
have you tried disconnecting the power for about 15 minutes to see if it clears
anti crease refers to the dryer continuing to tublme for about 10-15 seconds every 5-10 minutes so when cycle is complete the clothing doesnt just set there where wrinkles can set in ,it tumbles after end of cycle to prevent wrinkling
Jul 22, 2011 | Miele Novotronic T1515A Electric Dryer
My Miele Touchtronic T 9800 Dryer progrma works but when the dryer has ocmpleted its cycle, the cloths are still damp and not dry.. .I have to run the cycle several times to even get near dry cloths. what...
Hi dear.Try this,that should help you to solve the problem.If you need to download the user manual please click the link below.Thanks.
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T9802_us.pdf
Problem:The laundry is still wet. The program runs too long.
Solution:The air flow is insufficient. Check the lint filter, air intake and vent for obstructions(REFER USER MANUAL)
Aug 25, 2010 | Miele T9800 Electric Dryer
My Miele Novotronic W 844 Washing Machine will not completely spin dry my clothes. They are soggy at the end of the wash cycle. Help please! (My machine's settings are in German.)
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent from drain pump blocked.(Vent left front side of soap drawer. Visible when drawer removed)
Mar 19, 2010 | Miele Novotronic W1918A Front Load Washer
Miele T230C do no start
If start LED does not blink, most likely fault is your door lock.
Jan 04, 2010 | Miele Novotronic T230C Electric Dryer
My miele machine tends to bleach my clothes.
I would run a few cycles with just water added to the bleach dispenser, clean it out, and see if that helps.
Nov 06, 2009 | Miele Novotronic Premier 500 Front Load...
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
Miele Novotronic T1570C Electric Dryer Logo
314 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
