Question about Amana Refrigerators
Buzzing sound every couple minutes seems to be coming from freezer. Freezer dorsn't seem to be real cold????
  • dollkarl Sep 15, 2010
    model # abc2037dts
    ser # 10015951e1 sound is coming from inside / back of freezer
    President:
  • 1,961 Answers
Please specify the exact model of the refrigerator. And where exactly the sounds coming from? inside or outside? from the motor?
Please post back so I can give you further help. Thanks
Posted on Sep 15, 2010
  • 2 more comments
  • Danilo Baraquiel
    Danilo Baraquiel Sep 15, 2010
    In this image please pin point the exact location
  • Danilo Baraquiel
    "The villain strikes again". The buzzing sounds ans sometimes ticking sounds came from the relay. You will need to replace this parts, as shown in the image below. Its the most common problems facing the Amana refrigerator.
  • Danilo Baraquiel
    You can find the capacitor relay on this diagram
  • Danilo Baraquiel
    It is also will be helpful for you to see the assembly, wiring diagram and available parts for sale for Amana Ref ABC2037dts model that you can find from this link
    http://www.appliancepartspros.com/partse...
    Please comeback and rate this solution if you purchase and replace the parts that is needed to make your refrigerator work normally.
    Thank you for using Fixya.
    Alp
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Help!! A couple of days ago, freezer food thawed and. regerator food warm. There are some cold spots in freezer and frig, but not uniformly cold. Compressor seems to be working. There is a fan blowing...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 21, 2011 | Frigidaire Refrigerators
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Buzzing sound
the buzzing sound is the compressor trying to start. Unfortunately, it is locked up and the overload is cutting it out. It resets every couple of minutes or so. The problem is the compressor. You can try a hard start capacitor to see if it breaks loose, this is the cheap fix, otherwise it needs a new compressor, the expensive one.
Dec 05, 2007 | Amana ATB1935HR Top Freezer Refrigerator
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
