Question about Krell Home Theater Standard 7.1 7.1-Channel Amplifier
I need to connect a Krell HTS 7.1 to a Krell HTA using the DB-25 cable and to a Halcro MC-20 stereo power amp using a pair of XLR cables configuring the Krell HTS 7.1 to send the front channels signals to the Halcro amp and the other channels (center and surrounds) to the Krell HTA. How can I do that?
    President:
  • 2,777 Answers
You will need to use the pre-outs on the receiver to hook up your amplifier. I am trying to verify if that model even has pre-outs for the front channels, many do. You will be able to tell quicker than I can by just looking for outputs labeled pre-out for the front channels. Just use the cables you have to attach the Krell amp to those pre-outs and you will be good to go. Let me know if you are unable to locate them... the receiver may not be designed to do that..
Tim
Posted on Sep 15, 2010
I have a pair of jbl 512m speakers one is louder than the other one but it works
Make sure your audio interconnecting cables are XLR or TRS balanced lines. Use of TS cables similar to guitar cables with only two conductors (only the tip and the sleeve) reduce the gain 6 DB and contribute to hum and noise.
Sep 03, 2011 | JBL New Jbl Prx512m 12 Powered Monitor...
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
Nov 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
RS 232 cable manufacturer
Is 25 pin or 9 pin connector?
In either case pins 2 & 3 are Tx & Rx data, you might have to swap them.
On DB-9 pin 5 is GND, on DB-25, Pin 1 & 7 are GND.
Here is a link to a reliable source of pinouts for you to construct your cable.
Apr 06, 2009 | Computers & Internet
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Connecting a guitar amp to a mixer amp
Hi cliff
Connect either of the XLR DI output of the Behringer directly to a MIC IN channel on the Powerpod using a standard Microphone cable. If you wish to push a stereo sound then connect both(L + R) of the XLR DI outputs from the amp... that's about all you need to do. The only reason you need to use stereo(both XLR Outs) from the Behringer is if you want a full stereo FX output from the amp, otherwise you can get away with 1 connected. You may need to back the gain off for those channels on the power pod. You can get a manual for the Powerpod from here
and user manual for the acx900 here
Hope this has helped you, If not, feel free to ask any questions. Cheers.
regards
robotek
Aug 08, 2008 | Phonic Audio Players & Recorders
Adding 2 extra channels to pair a MC7205 with a MX119 pre/pro
Yes, you can connect the MX119 'Multi-Amp' output connection to the MC7205 using a 'Parallel' 25-pin cable. It will send Front_L/R/Center/Surround_L/R signals (5 total) to the MC7205, then use a separate pair of RCAs cable to connect the 2 back-surround signals to another 2-channel amp and you are all set.
Feb 09, 2008 | Mcintosh MC7205 5-Channel Amplifier
Hook up pair Bx8a to pc
XLR? not true. gold plated, balanced trs cables have a better sound and actually compliments the bx8's technology. that said, you can get cable that is trs-balanced on one end and rca's on the other. then just get a "Y" right-left rca into a stereo 1.5 cable. easy and cheap. but using xlr's for output? NO. save those for your input MIDI instruments and controllers.
Dec 28, 2007 | M-Audio Studiophile BX8a Speaker
Krell Home Theater Standard 7.1 7.1-Channel Amplifier Logo
93 people viewed this question
Top Krell Audio Players & Recorders Experts
80stech
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
