I have Uniwell dx 915 problem :- what is the network kind that can be done ? with and without Pc- server how i can make those 2 kinds be done ? what program that i need to do so ? i want to get all Z X report from Network. i want to get a;; report by network. sorry for my low lvl of English , d'like to get help as i have google around and i did not get any good information Best Regards,,,
XBRMann
  • 38 Answers
SOURCE: DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Posted on Apr 27, 2008
Shuttle83
  • 1139 Answers
SOURCE: hurricane h5200 modem/router
Hello jmazaredo,
Does your DNS server have your server fqdn in its tables, and does your PC have the address of your DNS server in its lookup table?
One test you can do is to use the hosts file to put the fqdn into and assign it an address this would let you know the the PCs can use host tables to do the translation then this becomes a DNS issue as opposed to a lookup issue and you cut your troubleshooting in half.
In other words edit your hosts tables (hosts file) with the entry (Example 1):
IPADDRESS FQDN ALIAS
192.168.10.2 somesystem.myhome.com. system
192.168.10.5 somesystem2.myhome.com. system2
This as stated will determine if you have a DNS issue or a lookup issue, because the DNS system will use host tables first and the do a DNS lookup.
Once this is done if it works then try this setup:
1) in your router set the DNS to capture the DNS of your ISP (normally the setting will tell the router to use the DNS given to it by the DHCP protocol.
2) turn on DHCP on the LAN side of the connection in the router and set the controls for proxy DNS service (using the router as the local DNS server also called caching DNS server), However set the router up to allow static IPAddreses and if possible to recognize the domain name of the local LAN.
3) set your servers up with static IP addresses and in their host tables set the fqdn up as stated above in Example 1
4) in your PC set the DNS to be the IP Address of your LAN side of your router i.e. 192.168.1.1 and if needed set the host tables of all PCs to the server addresses, fqdn, and aliases this way if DNS fails the system will at least have the host tables to use.
I hope this helps.
Thank you,
Shuttle83
Posted on Oct 26, 2008
drlalitv
  • 488 Answers
SOURCE: low signal need netgear name
  1. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
once you see the setup you can configure and change the name and security of your network
to find out which one is your network place the router as close to the laptop/desktop so that u get a strong signal
if u get other networks u will no yours if try logging onto them and it asks for a password..if u have not configured your without security then that network must be yours..
hope it helps..do letme know if u need anymore help..
Posted on Oct 30, 2008
k-n-tech
  • 34 Answers
SOURCE: cannot connect to internet
Make the Ip address similary to the router, example 192.168.1.25 should work.
SUbnet mask will then fill in automaticaly, just leave it
then Default gateway will be the routers IP. 192.168.1.1
the dns server would be the ip of your internet provider. I would leave it blank at first, see if it will work then. If not, then ask your service provider for it. If they give u a number, then you will have to go into the router properties, and change the dns and stuff like that in there aswell.
good luck
Posted on Dec 25, 2008
Just_Bobz
  • 448 Answers
SOURCE: VERY WEEK NETWORK IMEAN SIGNAL VERY LOW
Network signal strength is not based on your phone. It is based on the network. Poor sigal is their problem, Call them. If this rates as helpful, please post as such.TY
Posted on Feb 05, 2009
Uniwell dx 915
Any chance of some information on the problem? Like, make and model of the computer and the monitor. Plus a decent description of the problem?
Sep 16, 2013 | Computers & Internet
System health is critical. Red light flashing and system won't coming on
There is a critical system component hardware failure of some kind.
Front panel indicators:
1System power LEDGreen = Power on2Health LEDGreen = Normal3Power cap LEDGreen = Power cap configured4NIC 1 activity LEDGreen = Network link 5NIC 2 activity LEDGreen = Network link 6UID LEDBlue = Activated
Rear panel indicators:
1Power supply 2 LEDGreen = Power supply is on and functioning2UID LEDBlue = Activated3Power supply 1 LEDGreen = Power supply is on and functioning4iLO 2 link LEDGreen = Linked to network5iLO 2 activity LEDGreen or flashing = Network activity6NIC 2 link LEDGreen = Linked to network7NIC 2 activity LEDGreen or flashing = Network activity8NIC 1 link LEDGreen = Linked to network9NIC 1 activity LEDGreen or flashing = Network activity
Sep 09, 2013 | HP ProLiant ML370 G6 Server
Looking for programming manual of cash register UNIWELL DX895
I can download a program manual. Please list ROM ver
Regard,
Bob
Apr 02, 2009 | Office Equipment & Supplies
Problem in reboot the server in domain
This sounds like a common DNS issue. You need to make sure that this server has a local DNS server like 192.168.1.1 and not an external one like 4.2.2.2.
Your server is trying to find the domain controller and with the external DNS it cannot. This is why when you remove the cable it loads correctly. it assumes that it is disconnected from the local network and it continues without the domain controller. otherwise it waits for the external dns to time out.
Jan 25, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Uniwell 875
There is no paper manual for Uniwell, they have an online manual. Go to www.uniwell-usa.com It is very difficult to program without the software and unless you have done a few of them. You can order keys from a local dealer.
Sep 24, 2008 | Computers & Internet
Ftp server
What is the name of the software? Is that an FTP software?
Anyway if you are using DX-E401 Router you can enable DMZ (demilitarized zone) to your PC.
1.access your router configuration page (default ip: 192.168.0.1)
2.go to advanced tab
3.select DMZ
4.select enable then type the ip address of your server pc
5.apply settings
after that have someone try to access the files in your pc.
if the software you installed is ftp software then have them access it by this
ftp://internet_ip
the "internet ip" is the ip address found in the STATUS TAB of your router under the WAN catergory.
If this software you mentioned is using any particular application ports, you will have to open those ports for your server PC.
In that case you will to configure VIRTUAL SERVER. It's the actual term used by dynex. for you to have a general idea how to configure your pc behind your router please go to this link
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/DX-E401_Manual.pdf
Virtual server configuration is in pages 22-23. It has detailed explanation of the terms used.
Hope this helps!
May 07, 2008 | Dynex DX-E401 Router
Sound driver for gigabyte 915
Please let me know the company of your sound card.
Here is a site for downloading sound drivers
Click here
Dec 07, 2007 | Intel Motherboard
Dynex wireless adapter
When you posted "cant...dynex wireless notebook card...operate..." do you mean:
1. It is not recognized by Win98SE;
2. Will not install:
3. missing/error on drivers;
4. will not connect:
5. will connect but drop;
6. will connect but no internet access?
Pls post back details. Further to what AP/Router are you connecting to?
Kind regards.
Nov 04, 2007 | Intel Pro 1000XT Server Adapter...
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
