Question about Toro& Electric String Trimmer
Replacing spool line on Toro Model 51440. I have replaced it and when using, line continually breaks. Am I not doing something correctly.
5 Suggested Answers
  • 313 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
the problem is the white lever may be broken. its located at the bakc of the spool line,
Posted on Jun 01, 2008
radar001
  • 1051 Answers
SOURCE: How do you remove the line spool cap on a toro
There are 2 tabs, 1 on each side of the cap. You need to press these in at the same time to pull the cap off.
Posted on Apr 06, 2010
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
Posted on Mar 30, 2011
Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I don't know how to restring the weed eater
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spool
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have an 1100 TORO Weedeater with the "push tabs" to remove the spool. Thru use/mis-use, the "tabs" are all the way in and the spool will not release. There is still line on the reel...
All I know to help you would be parts replacement as plastic parts are wear items and have to be replaced. Here is a parts w/diagrams breakdown of the 1981 model year Toro 1100 trimmer. I hope this can be of help. You can order parts here to replace your "worn out" string head and spool.
http://www.partstree.com/parts/?lc=toro_consumer&mn=51300%2C+1100+Electric+Trimmer%2C+1981+%28SN+1000001-1999999%29
May 12, 2011 | Toro Electric Trimmer
I have 11" Toro Trimmer and cannot turn spool counterclockwise to replace line. I am a woman and do not know what to do. Used strap wrench large open end wrench and cannot budge this spool.trimmer is less...
With most trimmers, you may have to push the spool casing inward and then turn. It should unlock fairly easy. You may also want to spray the divider crease on the spool casing with some kind of lubricant like WD-40 or Tri-Flow to facilitate the process of detaching the spool casing from the body. Good luck. I hope this helps.
Jun 29, 2010 | Toro Electric Trimmer
Refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Apr 11, 2010 | Toro& Electric String Trimmer
I can't remove the spool to replace the line. How
there is a button on the end of the shaft. it can be tight sometimes so a large pair of channel locks might help. turn the button counter-clockwise, and the pull the spool head off.
Aug 30, 2009 | Toro Garden
Jun 03, 2009 | Toro Electric Trimmer
May 26, 2009 | Toro Electric Trimmer
Toro& Electric String Trimmer Logo
728 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
