Question about Boston Acoustics BA745 Computer Speakers
Plug doesn't go into woofer( bigger plug)
I disconnected the larger plug to the woofer, and now when I push it all the way in, the plug falls out, could i have pushed too hard and now the female end in the woofer has recessed?
    Sergeant:
  • 291 Answers
YES!!...........
Posted on May 18, 2008
How can a vibrating screen be used to separate dirt and rocks?
Vibrating screens can be used to separate different sized particles like rocks from dirt, by forcing the smaller particles to fall through the holes while the bigger particles will stay on top.
Jan 14, 2014 | Tools & Hardware - Others
I open my b212a and disconnected the speaker and horn wires and know i have completed my repair i am read to reconnect and i don't remember which set of wires are the positive side
Because the system is bi-amplified, it is important to replace the wires correctly to avoid phase problems. I don't know how the wires are colour coded, but if it is any help I downloaded the schematic and the wires are numbered 1: Woofer Active 2: Woofer Earth
3: Tweeter Earth and 4: Tweeter Active. Sorry if that's no help. Otherwise it should be easy to trace the wires to see which connect to earth.
Dec 12, 2013 | Behringer Eurolive B212A Speaker
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
No sound comingout now on my HT BD2T subwoofer,just humming.
Try reconnecting; then replacing the audio cable for the sub woofer. I think it is just a standard RCA cable.
When you disconnect the RCA cable does the sub woofer still hum? If so the sub woofer may be bad. If it falls silent chances are it's just the cable.
Mar 08, 2011 | Samsung Audio Players & Recorders
Whenever i turn on my car my subwoofers stay pushed out does anyone know what the problem is
your amp is probably bad and is sending dc voltage to the woofer. disconnect the woofer from the amp as this will eventually ruin your woofer.
Mar 12, 2010 | Car Audio & Video
If i put the TS-swx310 sub in a bigger box would it get help the sound.......i have a 12'' regular sized box and the speaker is going in a car now???
It is amazing the difference box construction can have on the overall sound of a system. Size is only one factor. Using a larger sealed box may make the sub hit lower, but not necessarily louder. Because the TS-swx310 is a shallow mount woofer, it is designed to run in small enclosure. Putting it in a much larger box could potentially cause damage to the woofer over time. If you want more bass my advice is to use a normal woofer in a box built to spec for it. Generally a ported box will provide more output, and sealed hits tighter. It all depends on the type of music you listen to.
Hope this helps
Please Vote & Rate
Mar 08, 2010 | Pioneer TS-SWX310 Car Subwoofer
Sony xplod XM ZR602
What ohm is your sub running at. Sounds like your runnig your amp to low an impedance causing it to thermally shut down, when it cools a bit it turns back on. Either that or you have wires crossed somewhere. Check your wiring and make sure the load of the speaker does not fall below the rcommended ohm of the amp. Usually 4ohms mono and 2ohms stereo
Sep 07, 2009 | Eclipse EA3422 Car Audio Amplifier
Change the belt on the machine
Usually the easiest way is to put the belt on the smaller pulley first and then start it on the bigger pulley on one side and then turn it onto the bigger pulley by spinning the pulleys to get the belt to direct itself onto the larger pulley little by little. Using a flat-headed screwdriver can help pry the belt on and keep it from falling back off of the larger pulley while turning it to get the belt fully on. If you have any other questions about this, let me know.
Benjamin
Jun 15, 2009 | Kenmore 22422 Top Load Washer
MACKIE SWA1801--Sound quality is not same
I suggest, go out and buy a heavier duty 18 and replace it.
Aug 24, 2007 | Mackie SWA1801 Subwoofer
Boston Acoustics BA745 Computer Speakers Logo
47 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
