All cables connected to my ferguson f20500dtr (not optical audio though) and while I can receive analogue signal through the box it says 'no signal' on the screen. scartleadworks fine from sky box to tv so can't figure out what the problem is. any ideas?
5 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
  • 3 Answers
SOURCE: Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Posted on Jun 26, 2009
SOURCE: E01 Error on pioneer plasma
I've got an E01 error on my Plasma TV . It's a Pioneer. There 's anyone who can help me? Tks ALX
Posted on Oct 15, 2009
SOURCE: My Ferguson F20500DTR currently has
Did u resolve this problem cus I'm having the same problem.
Posted on Jul 05, 2011
Kenwood vr 306
If your TV has a headphone socket then you can use that.
If not, then because very few TVs are fitted with a basic stereo audio out then you need to use the TV's Digital Audio Out instead. This is probably on an Optical connector.
A lot of receivers have a direct input for Optical. I don't know the VR306 though. So if yours doesn't, then it needs the signal converting from Optical to analogue audio. This is a conversion from light pulses in to a basic stereo electrical signal. This can't be done with a piece of wire or with adapter plugs. It needs some electronics to translate the signal from light to electricity.
The adapters range in price up to 60 Pounds sterling. But here's one for peanuts from Amazon Cable Mountain Digital Optical ToSlink Amazon co uk Electronics
Sep 09, 2014 | Audio Players & Recorders
The speakers on TV mode work but when I go to play DVD no sound.
How have you connected sound from the DVD player to your AVR-5805? If optical (a good choice because it sends surround sound with one cable) then you will need to choose optical audio in your DVD signal path. Similarly, you need to choose analogue if used or even composite (not a good choice)
Sep 29, 2013 | Denon AVR-5805 Receiver
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
When running the auto install i receive the following error despite an optical cable connected to my cable box: - Connect an optical cable from this product to an external digital device such as a cable...
Optical cables are easily damaged by excessive and sharp bending. Since optical relies on light pulses it is important not to pinch the cables or cause them to form corners, as this will reduce signal quality and possibly damage the cable from being able to send or receive signals at all. Try a different cable and make sure the proper out goes to the proper in. Hope this helps.
Jul 11, 2011 | Audio Players & Recorders
I HOOKED UP THE AUDIO CONNECTIONS FROM MY CABLE BOX TO THE BOSE RECEIVER. THE SOUND DOESN'T SOUND MUCH BETTER THAN MY TV SPEAKERS. WOULD USING A FIBER OPTIC CABLE MAKE MUCH DIFFERENCE?
You don't state how you have connected it but even with an analogue cable the sound should be better than your TV speakers, unless you have fantastic TV speakers, so something else is wrong however yes it should be better with as the full stereo surround signal is (if supported by your cable box) is transmitted digitally over the cable, so any analogue problems such as bad connections etc will be eliminated. I would not however buy a cable until you figure out whether there is a problem with your cable box or the Bose, do you have access to another source and connecting cable you could try first? Also go into the cable box menu and check if the sound out is correctly configured. Please rate my reply. Thanks
Jan 03, 2011 | Bose 3 2 1 GSX System
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
Recording audio only from an HDTV concert
Have a look at the manual for your AV receiver, you may find that you can change the digital output format between DTS mode and PCM(audio) mode. It needs to be in PCM(audio) mode for your CD recorder to be able to record digitally. If that doesn't solve it I can only suggest recording in analogue mode, i.e. taking a stereo analogue signal from your receiver to the analogue inputs of your CD recorder.
Hope this helps
HifiJohn
Jan 04, 2009 | Harman Kardon CDR30 2-Disc CD Recorder
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
Sound problem
I'm fairly certain this is a cable signal issue... I have had my digital audio cut in and out and the cable company traced it to a weak signal and replaced the cabling. No issues since. Just an FYI, my setup is a Sony 6.1 with an Optical cable. There is a Blue Light indicator for Surround and when I had the problem, the receiver's light would go off and the display "blinked."
Dec 17, 2006 | Aiwa AV-D57 Receiver
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
