Question about Frigidaire Affinity ATF7000E Front Load Washer
Washer drum made a ratteling noise when on a spin cycle and looks like it fell off the mount. Does not spin freely when you try move it with your hand.
  • Frigidaire Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Posted on Sep 15, 2010
When it gets to spin cycle it move all over the placy bang into wall ????
Check to see if the machine is level and all the 4 legs are making good contact with the floor. If the machine is level, check to see if the machine spins freely. Open the door and check the drum. It should be hang straight in the opening. Spin the drum by hand and listen for any strange noises. It should spins quietly without any banging noises. If that check out, remove the lower access cover and look at the wash drum. There are two shock absorbers. If they look damaged, they will need to be replaced.
Oct 04, 2010 | Frigidaire GLTF2940ES Front Load Washer
While finishing a load of laundry, during the final spin/rinse cycle the washer made an aweful pounding and banging noise. It was so loud I heard it from the other side of the house and went running to see...
Yes I do know unfortunely the basket support broke. This support is mounted on to the back of the basket and goes through the rear bearing and the back half of the outer tub. This is a very extensive repair .the unit has to be totally disassembled ,if it only broke the support it is about 100.00 , but if the rear tub bearing is also damaged you may consider replacing the unit with a new one either way this is an expensive and extensive repair...
Sep 17, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
My admiral washer ATW4475TQ0 makes a thumping noise at end of spin cycle and when lid is opened during spin. What could be wrong?
there are stabilizers on the drum if they have fell off or broken away the drum will swing wildly around on spin this will cause the drum to "hit" the inside of the washer,,,check the drum stabilizers are in good order
Aug 08, 2010 | Maytag Washing Machines
Whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
May 15, 2010 | Washing Machines
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
401 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
