Question about Refrigerators
Kenmore Elite refrigerator, double doors, bottom freezer, not making ice error code comes up er1f Model # IS 79577563600
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 15, 2010
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Kenmore Elite 79577563600 is showing Er 1F. What does that mean? I cannot adjust temp or ice or anything.
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#@%
Apr 07, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
KENMORE ELITE MODEL #79577563600 FAILURE COCE
Mar 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our kenmore elite bottom freezer is making a loud humming noise. It shuts off when door is open..and continues when door is shut. Temperatures are fine, no error message, it rarely stops..like it is trying...
Turned off the fridge, emptied the Freezer, used a blow dryer for 20-30 minutes, to melt ice that had built up in vents at rear of freezer.
Cleaned the freezer and reloaded...no hum..at least for now.
Sep 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
We have the kenmore elite trio bottom freezer refrigerator model 795.7756 - we have error message ER IF, we know the ice maker will not come on and have tried resetting it. How can we get the icemaker to...
Sep 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore elite bottom freezer unit displays an "er IF" message and water is leaking from the ice maker door. what does this mean? the manual doesn't help
Jun 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
H20 dispenser displays er lf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^#
May 05, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Control Pad displays Er CO.
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Nov 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
326 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
