My Maytag Atlantis Gas Dryer will come on, but will not dry clothes. We had a load of towels in before bed and had it on auto dry - next morning the dryer was still going. Disconnected the vent from the back and checked to see if warm air would blow out- but, only cold air. Can't hear the ticking noise - do you think it is the ignitor????
SOURCE: Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
SOURCE: maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
SOURCE: maytag neptune dryer not heating up to dry clothes.
On my dryer the igniter is rt behind the front panel. Take off the dooe and a few screws and pull it off. If the igniter lights at all it is good. Try also checking the entire discharge vent hose as sometimes it gets clogged way dn line and you might not notice it. Try squeezing it all the way dn.
SOURCE: My Maytag Atlantis MDG6400AWW will not heat up.
1. Ignitor needs replacing
2. Gas manifold needs replacing (less likely)
3. Make sure the temp controls are in proper setting
4. Remove lower panel of unit and look for ignitor to glow or spark when you start the dryer.
5. Remove ignitor and inspect for cracks, and check with ohm meter.
SOURCE: maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
My Maytag Atlantis Gas Dryer will come on, but will not dry clothes. We had a load of towels and some other smaller items and running it through it's cycle twice, the towels were still damp.
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
The dryer will come on but only blow cold air,
